maomi net dim multi bios
8,309CR
so i have a netdimm showing dims timed out on test ?
what is occuring ?
i have bought another multi bios because i thought this wass the problem ,
i gett 1 solid green light on the net dim and one flashing ,
if i change region dips to jap i get no lights on dim board at all ?
help needed please much apretiated
i got net dim from holland of a guy on otaku ,, im dreeding it being faulty ...
steling1
9 (100%)
272CR
Where are you based?, if your local to me I have a bunch of Naomi's that work fine with netdimms you can test it on to be sure.
What is the voltage of your setup?, the most common issues with NetDimms is that they are very sensitive to voltage (far more than the naomi itself), if they are exposed to over something like 5.2v (I cant remember exactly, but its in that ball park) then one of the chips just burns out and it becomes dud.
steling1
9 (100%)
272CR
Cool I’m in West Midlands which is prob a bit far....lol
It helps to have a cheap standard Naomi cartridge as a tester to see that the system is working without the net dimm, I use a virtua tennis cart which there seems to be millions of....
I typically get the voltage close using the Naomi with a cart installed first then try it with the net Dimm and readjust from there to be safe...I know from bad experience of burning one out at too high a voltage sadly...:-(
. steling12018-06-13 00:00:19
big10p
Coins detected in pocket!
6,094CR
Did you check the DIMMs are seated properly? Might have come dislodged on the journey from Holland. Also check the daughter board is seated.big10p2018-06-13 00:06:26
Ace`
PlanB contributor #1
40 (100%)
4,043CR
I dunno about unrepairable
it is a common issue though.
8,309CR
Is the 512mb Supposed to have 2 dims?
I have a tennis 2 cart Naomi is operating ok
Apart from really bad buzz through the speakers I can only turn it up a little bit
Tried phono out on board to another speaker and same
It’s like needs grounding ?
steling1
9 (100%)
272CR
I believe they can have either 1 or 2 dimms for the 256mb and 512 mb varieties but I’m not 100%
Yeah that buzz can be a grounding issue or something else, i believe the type of buzz can help determine what it is (whether it’s high pitched, fast or slow, how volume affects it)....could be a bad cap etc
