Massive ROMs
5,332CR
I’ve been wondering - what do folk do when they need huge ROMs?
Can you easily get ahold of things like 27C320’s and do they fit much?
What do you program them with? (I’ve not checked, but I think that’s too big for my Galep4)
Just thought I’d see what was readily available and what’s ‘the norm’
phillv85
490CR
Capcom CPS2 boards use 27C322 EPROMs, and they're quite commonly worked on for conversions and phoenixing dead boards. I use my GQ4X for them with the expansion board.
5,332CR
Ace` said:
There's a 42 pin adapter for the galep-4, well there's a free schematic. Someone on here made pcbs and gave them out a few years back, I can't find the thread though. Mine still gets used quite a bit.
Edit:
Looks like it was Brettster and he offered you one here http://www.ukvac.com/forum/all-the-gear-no-idea_topic362418.html?KW=galep+adapter
Yes, got that and made it up
I’d looked before and didn’t see anything bigger than 4MBit on the supported devices. Was going to check again tonight, just involves digging out the steam powered old laptop. Marvellous if it does work though.
Thanks all
GadgetFreak
963CR
I buy 27c322 and 27c160 from China for an average of £0.80 each in batches of 10.
Can take a few weeks to arrive but have all been good so far, often they have some kind of industrial sewing machine firmware in them when they haven’t been blanked. The ‘160 ones are quite handy as they can also be used in 8 bit mode.
Real irony is that they are just about the cheapest EPROMs you can buy!GadgetFreak2018-07-10 21:39:26
5,332CR
Ah, found it - was searching for 27c320, not 322.
Not a fan of the search in the Galep software.
Great if they're cheap too. Looking much easier than I expected.
Thanks again.
Oh and as proof I did make up the adaptor
Ace`
PlanB contributor #1
40 (100%)
4,040CR
Now you need to mod it so it fits in the galep zif socket. I cut a notch in the pcb with a dremel but I guess using longer pins is the best way to do it.
ColinD
6 (86%)
1,367CR
Yes, that was my fault when I laid out the PCB !! - I didn't realise that it all went in upside down so placed the Pins to the top left so the lever would clear, completely the wrong corner. There are extra pads that were for larger Zif sockets if you could not find a 42 pin one.
5,332CR
Just a quick bump to say, as Gadgetfreak says, 27c322's are cheap (think I paid 90p each). Whether they were 'new' or not, I don't know, but were blank.
Program and verify good with the UKVAC adaptor too
So all would be marvellous if I hadn't forgotten how to do maths - I need 64Mbit
. I think a flash PCB might be the way to go for that.
