Matrix Errors.... next SW repair
karlcdoe
887CR
So... CPU board matrix Errors as below, I have checked the obvious such as swapping out the mathbox PROMS and RAMS and verifying all the eproms on the main board. I had a quick poke around the clocks, matrix and accumulator hardware with a scope and ABI boardmaster but I haven't found anything yet (yes I may have missed something as it was a general 'shotgun' test strategy).
Now I am trying to make more sense of the messages it's actually giving me, so from the self test I get bad data on several tests and it looks like a bit is stuck high but am I right in thinking I need to select one of the hardware tests that fails (eg 16) using the diag test point and dip switches to keep it in that test loop and then look at the data that is sitting on the six data lines of the two matrix RAMS or the addressing on MPA0-9 as listed in the TS guide?
I was thinking it might be a dodgy singe wipe socket although I wouldn't see how an output line could be stuck high through bad contact. I have taken the liberty of converting it to binary and padding the leading digits with zeroes which I assume makes sense and does seem to suggest a stuck bit as the tests that pass would appear to leave that bit high anyway:
TEST DATA (expected and actual result)
16 AAAA 1010101010101010 (expected)
ABAA 1010101110101010 (returned)
19 2AAA 0010101010101010 (expected) (2AAA-0000) x 4000 = 2AAA
2BAA 0010101110101010 (returned)
20 2AAA 0010101010101010 (expected) (0000-2AAA) x C000 = 2AAA
Accumulator
A walking ones test, should return 0001, 0002, 0004, 0008, 0010, 0020, etc
0001 0000000000000001 (expected on first increment)
0101 0000000100000001 (returned)
Block Index Counter & Matrix processor Indirect addressing
B 0000 (returned) - no value given in the in TS guide.
Accumulator Adder
C 3496 0011010010010110 (expected)
3596 0011010110010110 (returned)
I should probably mention that I removed all the socketed devices and the crystal before using the boardmaster so I suppose it is possible it reported a line as 'high imp' as apposed to short +5v as a result *if* one of the devices is behaving erratically.
cheers
Karl.
karlcdoe2012-09-06 14:37:50
Mitchell Gant
888CR
Yes, ground the diag test point and select the DIPswitch for test 16 and it will keep in a tight loop running that test, so you can 'scope the various pins of the mathbox chips. I leave the sound board off altogether so I can get access to the main board mathbox chips more easily.
I'd guess from your test results that accumulator bit 8 is stuck high, which could be the 74LS299 at location 6D, pin 16. Or a PCB trace associated with that pin. I'm assuming it's failing tests 16, 19 and 20, but passing test 17.
  • Like
Reactions: trm
karlcdoe
887CR
Yes the other tests pass.
Anyhow, you were spot on with the above so thanks for that saved me further hassle and it now works.
The annoying thing is the signal didn't look stuck high on the scope, noisy maybe. I removed the chip anyway and my IC tester showed a stuck pin. Odd, must be me, anyway I have removed the chip in one piece and socketed it so I shall swap it back in later and retest the signals to see if they look substantially different. Good job the self test is so verbose really....
Karl.
  • Like
Reactions: trm
