mega-tech motherboard sound problems
Ace`
PlanB contributor #1
40 (100%)
4,038CR
I've got a mega-tech motherboard that has missing sounds. For example Sonic 1 has only half the intro music and no sound when collecting rings, no 'sega' when it starts etc. Some games like Altered Beast have no sound at all. The AMP and YM2612 seem to be ok, not sure where to go from here the board is a real bastard to work on with lots of hidden traces and small ic holes like on outrun boards.
trm
2,877CR
How did you determine the YM is ok? I'd probably start by looking in MAME/MAWS and getting some idea of how the sound system works - synthesised versus sample playback vs any other method of sound generation.
Once I've established the different sound creation methods I'd have a play in MAME to try to figure out if you're missing a set of sounds (e.g. bad EPROM) or a sound generation system (e.g. sample playback or synth).
I'd also check out the op-amps by feeding them some known good input (e.g. cut the end off a headphone cable and feed some low volume sounds from an MP3 player) into the various input channels and seeing whether any don't follow through to the power amp. If you've not got a method of injecting sound then you can probably get away with a bit of wire from your finger to the op-amp input pins as your body should provide enough mains hum for you to hear it.
In fact, I'd go check out the op-amps first as I can't recall how many sound fixes I've made just by swapping out the op-amps. And make sure you test all channels if you have a dual- or quad-channel op-amp. I've seen plenty where only a channel or two have gone pop and left the other channels in the same IC still working.
cheers
tim
trm
2,877CR
Saw your message on irc about the apparent lack of op-amps on the board. Does it need an external audio amp? I'm really surprised that it doesn't have any op-amps, unless all amplification is done on an external board. Even so I'd expect the first stage amplification and band-pass filtering to be onboard as the signal levels are so low that running the audio to a separate board would likely introduce lots of noise and AC hum.
Alternatively if you can link to some schems I'll have a scan to see how the audio works.
Tim
Ace`
40 (100%)
4,038CR
Managed to fix this today using my lovely new hakko desoldering station (new to me anyway).
Turned out it was the YM2612 even though it 'looked' to be working as it should.
Thanks Tim for your help.
Also meant to say that I took the YM2612 from an old mark 1 mega drive if anyone else ever finds they need one you'll know where to look.
Ace`2010-11-18 17:19:47
trm
2,877CR
Hi dude,
Sorry I'd not been back to help on this. Various members of my family all deciding to have babies almost simultaneously meant I got a bit distracted.
Good to hear it's working though, especially given the lack of schems. How did you prove it was the YM in the end?
tim
Ace`
40 (100%)
4,038CR
No worries Tim got there in the end, it was pretty much a case of ruling everything else out that it had to be the YM. All the caps checked out with the esr tester, I knew the amp was ok and I swapped the z80 board over with a known working one.
Nes4life
1,134CR
Necro-bump!!!
Been working on the exact same issue for @Nickygod! Just put in an order for a replacement YM.
Tested all the connections (as my own board had broken traces going to the YM) and they're fine.
Here's something for anyone investing sound issues on the Megatech:
