Megatech with issues
JohnnyChaos
Blows own trumpet for CHQ cabs
325CR
Ive got a couple of things to look at on this.
1. No red.
2. Game select changes games, but the same one is always highlighted on the top screen.
For the red I guess I'll be checking pots and wires first... Not even sure what monitor is in it yet. Looks hantarex from the bits I've seen.
Game select I guess cables again.
Any other things to check? :)
stevebm1
39 (100%)
1,274CR
sounds like a main board issue,if the carts are playing the games ok,but not changing on the info screen,could be where the colour problem is coming from to,do you have anyway you can hook the monitor up to another cab/set up to test?
trm
2,877CR
Hi dude,
Is this one of those dual monitor things like a Playchoice? I'm going to look for schematics to see how the cart select works but at a guess when you push the game select button it selectively enables a cart slot so the motherboard CPU can see the ROM data on the cart and run it. If so, I reckon the fault is with whatever system updates the "you have selected game XXX" display as the motherboard must be seeing the correct card to play it, but for some reason it's not incrementing the game display part.
Do you have a logic probe? If this works anything like I expect it to it should be pretty easy to test the theory. I'll be back after I've found the schems :)
cheers
tim
JohnnyChaos
325CR
yeah its like a playchoice but no I don't have a logic probe.
It did come with 3 spare motherboards although I believe none of them work. But if there was a specific chip or something I could swap parts over :)
trm
2,877CR
Cool. Have found some docs and am looking for the cart select/update logic.
Do you have a test meter instead? We should be able to hack it through with that :)
Although my mission for June is to get everyone who posts in Tech to pick up a logic probe as we'll have an army of PCB repair dudes once everyone realises how much sh*t one can fix with just a probe and an iron! I would post you one out but I think I've given all my spares away now
trm
2,877CR
Cool, we can definitely get somewhere with a test meter if I can find the schematics! I've found lots of copies of the manual but if you want to start trawling the sticky in the top of Tech that lists schematic sites please feel free
. We're after the Mega Tech schematics which unfortunately aren't in the Owners Manual.
I'll have a look for some probes on ebay tomorrow if you like? Should be about £10 but you'll save that in PCB repair postage the first time round, discounting the satisfaction from realising a lot of this stuff is very straightforward once you've had help with a couple.
trm
2,877CR
Heh. If some dude can make it, it shouldn't be beyond us to fix it. 'Cept there are seemingly no schematics.
Excellent dawn breaking outside, so early morning photo trip, bed, Mega Tech
JohnnyChaos
325CR
Yeah I didn't have any luck either. Does that put an end to the fix?
I can't get in the back of the cab yet to have a look at the rgb controls on the monitor
stevebm1
39 (100%)
1,274CR
the main monitor is a pig to work on in these when fitted in the cab,even with the back access panel and top of cab panel removed,there is still a piece of non removable rear panel that covers the neck board and most direct route to the chasis,I ended up taking mine out from the front to work on whilst it was fired up
trm
2,877CR
Got to say it's not looking good unfortunately. I had some more time looking yesterday too and I think it's safe to say the MegaTech schems don't exist in public
Can you get some good clear and BIG photos of the main board and any PCB (not monitor chassis) which links to the top screen? We might be able to figure something from that but I suspect the top screen will just have RGB&Sync from the single mainboard.
Bah!
JohnnyChaos
325CR
I had a cab go tonight so got room to have a little look in the back. Checked continuity on the red from the board to monitor and fiddled with the pots. The connection seemed fine and the pot didn't help.
I'll sort some good pics out after tea :)
JohnnyChaos
325CR
Here's a quick pic now I've fixed the monitor
Just got a replacement psu.
It still doesn't highlight the correct game, but it gives you the list and you can select and play them all fine so that's good enough for me :)
