Mercs CPS1 issues
seanr28
9 (100%)
319CR
Have some issue with the above game
Working but has graphics issues. Some parts of the graphics are missing and the player/enemy sprites are flickering, any suggestions please?
I have also tried another CPS1 A board (which definatley works as I have tested with Street fighter 2 Champ) but when connected to the MERCS B and C boards the whole screen is garbage but sound can be heard.......what am I missing please?
regards
sean
2,265CR
Sounds similar to the problem I had with mine. That turned out to be a bad PAL chip on the B-board. O224B. Replaced that and it worked fine.
seanr28
9 (100%)
319CR
thanks, out of curiosity how did you manage to get t down to just that chip being at fault?
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
from what I remember I think it was porchy that did the repair
seanr28
9 (100%)
319CR
ok, what about the different CPS1 boards, I have 3 of them in total, but the one for mercs is very different and one that came from SF2 wont work with mercs at al??
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
CPS1 came in 2 board types
they cant be interchanged and the PAL chips are different for each game too
they are usually socketed so if they fail can be changed
seanr28
9 (100%)
319CR
thanks, thats useful....will check later,
where would i be likely to find a replacement chip if that the case?
2,265CR
Both A-boards should show exactly the same fault. If not I'd test the MERCS A-board on SF2 and see what happens there. You might have more than one bad board.
I had 2 MERCS pcb's one was fully working, the other had graphic glitches and flickering sprites so I just swapped over the socketed chips until I identified the bad one.
seanr28
9 (100%)
319CR
but I thought that some of the A boards are incompatible?? I know the SF2 A boards look very different to the ones on mercs and final fight for example?? will test in a bit anyhow though.
seanr28
9 (100%)
319CR
ok, just tried it and it works on my other 2 A boards, so its definatley a faulty A board, any suggestions on who best to repair? or things to check?
could some of the dip switches be causing an issue?
seanr282015-03-02 15:37:46
pulstar
41 (100%)
459CR
All A boards are interchangeable.
There are the longer version and the shorter versions of the A board (the longer ones are older and are made up of mostly though hole components, the short versions have more surface mount components). There are also Dash variants, which have a faster CPU, these will play all games, it'll just some of the older games faster (such as Final Fight).
2,265CR
I'd bin it. They are extremely difficult to repair even for the guys who really know their stuff.
If you've got working ones look after them. A-board seem to be dying off rapidly. From my own experience the shorter later revision seem to hold up better, it's all the long ones that have gone faulty for me.
seanr28
9 (100%)
319CR
even though it works, with just some sprite issues? surly that must be fairly easily repaired? I would be inclined to agree if it was totally dead.
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
you want to send it to Australia or USA then its possible to repair
but here most guys wont touch an A board to repair
its possible to repair but its a real pain in the butt that no one cares for their repair
