Midi cab plans
cools
I joined ages ago honest
19 (95%)
799CR
Been fancying a compact wood cab for a while now but I've not really seen many that I actually like, nor that would suit my purposes without extensive rework.
So I figure I should just draw up plans and make one myself. Or rather, draw up plans and get one of the many cab builders to do me a CNC flat pack.
Here's what I've got so far. The whole thing is 18mm wood, and everything is straight cut - no mitres at all. Not sure exactly how well some of the joins between panels will work but I see these other guys making bartop flatpacks and doing the same thing with many happy customers...
Kinda modelled as a combination of all the cabarets I actually like, mixed with a Galaga upright.
Now, my reason for posting in here - I need measurements for monitors! The corner to corner measurements for the mounting posts. The angle I've chosen should allow any monitor to fit horizontally or vertically, but I'd like to template a couple of standard size monitor mounts to see what works and if anything needs tweaking. Hoping to get a 20" in there but I've not got access to a 20" monitor, and I don't want to be doing any woodwork whatsoever.
Can anyone help? Google's not been much use.
Oh, once I'm happy with the plans I'll upload them somewhere in case anyone else wants to do the same thing.
Judder
1,009CR
Here's some pictures of my cabaret SubElectro - Vartek Kadet machine
It has a 14" monitor I believe which can be rotated to vertical (for shooters) or horizontal (for Jamma stuff)
The monitor was identified by some nice people as a TOE monitor with a Peter-Chow 7amp psu
Hope that helps!
Happy to take any measurements you need when I'm back in London next week and near the machine
Milky
16 (100%)
1,037CR
This is a 19" I've got if these help? Talk me through exactly where you need the measurements and I'll go back out and get them. Hopefully, this gives you an idea:
cools
19 (95%)
799CR
Milky, if you could note the tube number and the dimensions of the mounting lugs where the tube is screwed into the wooden mount that'd be great.
I'm trying to find the various aperture sizes.
I've just realised I could probably go look at a Hantarex manual, but it'd be worthwhile checking reality against documents for this.
4,058CR
If it's a cabaret / mini / midi (whatever you want to call it) then a 19" shouldn't fit
Cabaret's have 14" monitors, with the only exception I really know of being the Tempest and some other Atari vertical ones.
If you plans are good, small, and for a 14" cab then I could be interested.
Milky
16 (100%)
1,037CR
No probs, I'll pop out when i've put the boy to bed
strykr
1,351CR
My little cab is prob around a similar size,
let me know if you need any other measurements other than milkys. Dont forget to factor in the neck length of the tube, some of these smaller ones with 19" monitors can only go horizontal.
gavinb
34CR
I need it back now
cools
19 (95%)
799CR
Heh, well I'm working from a candy perspective, fit the biggest monitor in possible! I started with a 50cm square base and worked up.
Tube length is something I haven't been concerned with yet, as its straightforward to adjust for later on. The diagonals are a pain to adjust for though.
The Hantarex manuals haven't been any help, though I've discovered that the mounting lugs are called monitor ears.
2,265CR
Electrocoin midi is a good cabaret cab to get monitor fitting measurements from, they use a 19" in either Hori or vert and the viewing angle is nice.
Edit: so is the Taitel T-83 cabaret which is almost identical. I have one and will take some measurements tomorrow.muddymusic2014-04-16 20:08:33
Milky
16 (100%)
1,037CR
This is a hantarex, not sure of model no. all the labels are borked:
Milky2014-04-16 20:34:59
cools
19 (95%)
799CR
Ahh, no sorry - where the tube mounts into the metal frame then - the corner lugs.
Doesnt look like they're accessible without removing the wood. No problem if thats too much hassle.
Milky
16 (100%)
1,037CR
Ahh, yes; I saw those and figured they might be what you wanted
I'd have to remove that and the missus'll go mental if I'm out in the garage instead of babysitting. I'll take the front off tomorrow if you can wait 24 hours or so?
cools
19 (95%)
799CR
Dims for smaller monitors would be good as well ;)
I've got a couple of 20" Sony PVMs doing nothing that'd be ideal, albeit they are literally the size of the case internally, there's no fancy angling that could be done to reduce the depth of the cab.
And I know there are truckloads of 17" PC CRTs around for next to nothing.
Thinking along those lines I've got a 15" in storage that might be the most suitable. And a 25" I've been hoarding as a spare...
Trying to strike a balance - I've decided on the lines it's just a matter of tweaking enough to be flexible. 20" may be entirely unsuitable.
cools
19 (95%)
799CR
Oh, and if possible the first few characters from the tube itself:
A34, A36, A48 etc
Nowhere seems to have it all documented :(
