Midway Invaders Transformer
funhouse
362CR
I have a Midway Space Invaders transformer that I think has failed.
MSItrans&
Testing from the Neutral (black/orange cable bottom left of the photo) to the transformer pins I get the AC readings as followed:
X continuity between 16.5 and 0 is lost
Displayed: 16.5 9 0 9 16.5 0 12
My readings: 0 0 0 0 0 21 21
MIDWAY MFG. CO
MT-59
Displayed: 0 6.3 115 220 230 240
My readings: 242 242 242 242 242 242
Additionally all the primary connections show continuity in the coil. The secondary do too but only either side of the 16.5 and 0 pins. I guess the voltages and continuity to the right of these implies a broken cable in the secondary coil.
Anyone know if I am testing it right and if this could be fixed somehow?
Cheers!
bomjac
453CR
MSItrans&
<span style="line-height: 16.8px;">Testing from the Neutral (black/orange cable bottom left of the photo) to the transformer pins I get the AC readings as followed:</span>
</span>
                                        MIDWAY MFG. CO
                                                 MT-59
<div style="line-height: 16.8px;">Displayed:              0       6.3    115     220    230   240
<div style="line-height: 16.8px;">My readings:        242     242    242    242    242    242
Additionally all the primary connections show continuity in the coil. The secondary do too but only either side of the 16.5 and 0 pins. <span style="line-height: 16.8px;">I guess the v</span><span style="line-height: 1.4;">oltages and continuity to the right of these implies a broken cable in the secondary coil.</span>
Cheers!
The bottom of the transformer is you ac input. On tbe primary side you should have 240v connected to the "240v" mark and neutral to the "0v" if it is wired for 240v. All of the bottom rails should be tested against the neutral (or ground) of the incoming mains. Across the 240 and 0 of the primary you should see 240 volts.
The 6.3V is probably an ac tap off for some small 6v lamps. Between 6.3 and 0 on primary should read 6.3v ac.
The top side is the secondary. From the markings it looks like you have a 16.5v and a 9v centre tappedal AC. Across the two 16.5 marks you should see 33v, across the two 9 marks you should see 18v. 16.5 to 0 should read 16.5, 9 to 0 should read 9. Finally on the right hand side between 0 & 12 you should see 12v ac.
On the primary side if you see 242 on all pins then you likely have a break between the "0" on the primary and neutral - the break could be in the cab, the cable or the plug. Could also be the door interlock switch - usually these break both neutral and live, but if for some reason the interlock switch is only breaking 1 phase and it is wired wrong polarity that could also be the issue. The door interlock switch can usually be pulled fully out to defeat it or sometimes you will see it held closed by insulating tape.
First thing to do is fix the issue with your incoming 240v then take the readings again across the correct primary and secondary points. You should only be testing the secondary connections to the secondary side, not the primary.
bomjac2016-07-13 12:45:47
funhouse
362CR
Thanks guys! Bomjac you were right, the door interlock had a bad connection. I cleaned it up and these are the readings between pins now.
8.5 10.3 10.2 8.6 16.1 13.6
MIDWAY MFG. CO
MT-59
6.8 115 110 11.4 9.9
They look good to me.
I noticed that the neutral wire connection is on 230v and the live is on 0. Is it best practice for me to swap the plug Neutral and Live over to be correct?
bomjac
453CR
Neutral should be on zero volts, yes. But be careful - the US standard is black for live and white or grey for neutral. The live should be connected to the mains fuse, and the neutral to the neutral.
If the wrong polarity it could mean that the fuse will not blow on a ground fault or if the fuse blows on short circuit the transformer could still be live.
Test the incoming live to ground. Should read 240v, and neutral to ground should be around zero, but can be in the tens of volts if you supply is unbalanced.bomjac2016-07-13 14:27:55
funhouse
362CR
Thanks. The cable has no colours but following the mains plug pins continuity I could see Live and neutral were swapped. All okay now. Thanks for the help. Now onto the power supply. Cheers. Stuart
tiburcio
3CR
Hi,
Im have also an SI with an MT-59 and its set up for 220v. Can I turn it into 110v? If so can you help me out with the correct way of doing that (including the monitor part).
Thanks in advance
T
