Midway Space invaders help!
Ronnie Dent
1,206CR
I need some advice and help please to fix this board! bit of a long story but here goes, the game was working but had some dots top right which would come and go or it would get dots all over the screen and go mad then reset, or at the same time the invaders would step down rapid like without moving left to right. But then it might work fine for hours?
Anyway thinking it was a ram issue I bought a braze kit for it and fitted it today it passed the ram test and worked great for about an hour then the above started happening but it would still reset and pass the ram test etc. But now it constantly resets with the braze fitted it just goes over the screen test and never reaches ram test? so I removed the braze kit and it will show the start screen " let's play space invaders" as soon as that is written it resets and does the same thing over and over? All the voltages read good I even checked the 5v on one of the chips, I have replaced the cpu socket today and even tried another cpu! so I'm stuck now! not sure what to check? any advice welcome and appreciated as I'm on a downer what with the Asteroids Deluxe not working either
Thanks Ronnie
Ronnie Dent
1,206CR
Can anyone help me out please?
Got another board that is dead on the screen only observation I have made is C5 is cooking slightly it's a D3245?
I need to make an extender for the edge connector so I can get at the board with a probe, otherwise it's a pig to get at!
Thanks Ronnie
Equites
Chief Sheesher®
35 (100%)
3,329CR
Thanks Ronnie
D3245 does run hotter than most ICs. SI is not the easiest boardset to troubleshoot. I would suggest the Braze diagnostics but you have already tried that.
Ronnie Dent
1,206CR
Thanks Ronnie
Thanks for the reply, yes I thought braze would be the answer too. but with my board stuck in a reset loop and the other dead I'm stuffed! I have 3 boardsets probably one could be called scrap!
D3245 gets way hotter on this dead board than it does on the cabs own board. I was hoping these boards would be way easier than Atari Deluxe
Thanks Ronnie
bonehead
I'll get pix tonight
50 (100%)
1,729CR
I too have a braze multikit and had a faulty si pcb. As the board was not booting properly without it installed it did nothing when fitted. From what I understand the board needs to be able to boot before it can tell you any faults.
I hope you get it sorted and your asty deluxe as I have just picked one up that is a project.
Steve
Ronnie Dent
1,206CR
Thanks guys, all this reminds me how difficult it is to keep these old games! it can be soul destroying! I guess I might need to try and get someone to repair these but determined to give at least the si a go
Ronnie
Ronnie Dent
1,206CR
I rigged up an external screen so I can see what's happening without running round to look!
I think I have narrowed it down to the main board as it's in a reset loop with 2 different sound boards? so it looks like I have-
1 cpu board stuck in a reset loop and another which appears dead but it must be producing some kind of video signal as the screen goes from blue to black at power on?
Ronnie
Ronnie Dent
1,206CR
The 8080A CPU pin12 reset is lo but flicking Hi in time with the game reset loop? pin13 HOLD is staying LO, I have all 3 voltages present on the CPU, all the data lines are pulsing, not sure what's next to check?
Thanks Ronnie
Steve67
25CR
What's the time between resets? About 4 seconds?
From the schematics, the CPU should be hitting port 4 to reset the watchdog periodically, otherwise it will reset every 4 seconds. There are loads of reasons why it might not be setting port 4 if the ROM's and or RAM's are bad, but it could also be a watchdog / addressing issue.
Check pin 1 of D2 and E2 .. should be pulsing quicker than the reset. What do you see there?
If that's not pulsing, it could be the 7442 at E3 (port decode) or whatever is at F2 buffering the CPU address lines - can't read the chip type from the schematics!
Good luck!
Ronnie Dent
1,206CR
Hi Steve, thanks so much for your input it is very much appreciated
Yes reset is every 4 seconds, D2 pin 1 is stuck Lo E2 pin 1 is solid pulsing HILO but LO flickers with the reset, The fact that D2 is Lo does that point to 7442 at E3?
Oh with each reset I get lots of random dots or very few or sometimes none? it changes each cycle?
Thanks Ronnie
Ronnie Dent2015-08-07 18:11:04
Steve67
25CR
Pin 1 on D2 (74161) and pin1 on E2 (74161) should both be connected to E3 pin 7 (7442) so they should look the same when probed!
Check continuity between those 3 pins with power off. D2 pin 1 sounds suspect if my schematics are right - can you confirm that D2 and E2 are 74161 and E3 is a 7442?
Are any of those chips socketed?
Ronnie Dent
1,206CR
Steve67 said:
Hmmm ... Just realised that these chips for the reset timer are on the board without the CPU / ROM / RAM ....
Ah on the daughter lol will start again Steve, will report back, thanks again
Oh but wait I have 2 of these boards doing the same reset but will check D2 and E2 pin1 on the daughter board
Ronnie Dent2015-08-07 18:44:11
Ronnie Dent
1,206CR
Steve67 said:
Do you have two daughter boards? If so, do the symptoms change when you swap them?
Yes 2 daughter boards but symptoms stay the same 4 sec reset loop?
That all ties in with D2 E2 on the daughter board but both pins 1 stay Hi solid? they both connect to E3 pin 7 as you said.
It might be possible that both daughter boards have been damaged in the same way by me swapping boards around on the other cpu board? as my set was booting fine prior to doing that!
Thanks Ronnie
Ronnie Dent
1,206CR
This is weird! I put it's own daughter card back and it worked? well the reset loop has stopped but it will be fine then fill with garbage and reset or it will freeze but only done it twice in about 5 mins, also seem to have no sound but that might be my edge extender loom, not sure what's going on with it!
Ronniw
Steve67
25CR
Hmmm ...
I doubt both daughterboards are dead in the same way - I suspect something is wrong on the CPU board but at this point I'd dig out the fluke 8080a pod.
One last try .. F2 on the CPU board, check Pins 1&3 should be the same, pins 4&6 should be the same and pins 8&9 should be the same on the probe. If those pairs match, Check each pair against E3 on the daughter board .. Pins 15, 14 and 13 respectively.
Ronnie Dent
1,206CR
Steve67 said:
Messages crossed - ignore my last post.
Re-flow the edge connector perhaps?
Thanks Steve, yes that's worth doing, the contacts are good as this board is very clean, will give that a try, hard to know if maybe both these sound boards are good and maybe a hit or miss edge connector. will keep at it, thanks again for your help it's been valuable. If it comes to the worst do you do repairs?
Thanks Ronnie
