Millipede PCB issues
Purity
The Oracle
17 (100%)
2,999CR
I was wondering if anyone could suggest what to look at next with a Millipede pcb please?
So far I have confirmed:
1) All roms ident
2) Voltages to the PCB are good
The PCB is watchdogging. On bootup I see the following screen:
If I disable the watchdog I see this:
I had a look at the clk signal. At pin 39 I see this:
At pin 37 I see this:
The following chips have been replaced on the PCB and are in sockets so verify good.
245 @ 4E
244 @ 1C/D, 1D/E, 1F
The rams @ 2E and 2F have been replaced with 2114-2 ram, and check out good
Any thoughts please?
5,415CR
No idea on that as you know more than me on pcbs, be interested to see what you find with it and if i get much from my pcb when i get around to testing in the cab
DanP
Administrator
2,232CR
If it's like other PCB's that use Pokeys you can just remove them to get past any addressing errors they may be creating. The game won't play properly but you will see it running or not.
Ace`
PlanB contributor #1
40 (100%)
4,040CR
How do the sockets look? the usual single wipe rubbish?
If they're okay, I'd look at the address decoders part of the schematics next.
Ace`2020-04-08 19:23:29
smarty
Ready Player One
1,305CR
Hi Ben,
I’d be checking all the H & V sync timing signals, 1H,2H,4V,8V etc. followed by checking the outputs of the address decoders, the LS42 at 1B. This is selecting all the ROMs if thats got a bad output the game won’t run. Then confirm the 244’s address buffer and the 245 (connected to the CPU) are working, at least prove there aren’t any stuck or dead outputs,
I’d zoom round all these signals with a logic probe to initially see what’s what and if there’s anything that looks out of place.
sukhbir
46 (100%)
1,736CR
Hi,try replacing the 6502 socket that can sometimes be the cause also there’s a chip at location 9n which is a 74ls257 which can cause problems on the data bus.
yorkshire_spam
765CR
Have you checked the roms in cirucuit using something like a Fluke or out of circuit in a reader?
Do you have the schematics to hand?
I'd be looking at anything in the address decode or bus circuits to start with.
Purity
The Oracle
17 (100%)
2,999CR
I have tested both pokeys in my test device, and they have both failed. One partially, one completely,
Tested the 6502 and that's ok
I have tested the roms out of circuit and they all ident ok
I have tested with a Fluke and cannot read the roms
I have the schematics
Purity2020-04-09 16:17:23
yorkshire_spam
765CR
If the roms are good out of circuit but won't read in circuit then there's something wrong in either the addressing or data bus.
One technique I've used is to put the fluke in a loop reading an address in one of the ROMs, then check things like the _CS for the rom is cleanly pulsing low when it tries to read, check that the address lines are doing what they should, if all that side looks good but it's still not reading, then it must be a buffer or broken track or something on the data side.
Purity
The Oracle
17 (100%)
2,999CR
I forgot that I have already replaced the 6502 socket.
Also LS244 @ 1c/d, 1d/e, 1f are socketed and are good
LS245 @ 4e is socketed and is good
Will see if I can check 1b and 3e, 4h
Purity
The Oracle
17 (100%)
2,999CR
@Smarty
So 244/245's going directly to the CPU are good. The LS42 @1B looks like the outputs are ok
I will have a look at 1H,2H,4V,8V etc now
EDIT:
H and V signals look ok
Purity2020-04-09 19:32:38
Purity
The Oracle
17 (100%)
2,999CR
With the watchdog disabled, I can see that there seems to be something holding D0, D3 and D7 low. I can see this on the 2114 ram, roms, 244@1F, 245@4E, and CPU
I assume it is better to disable the watchdog and look for problems than having it enabled and constantly resetting?
