Millipede (with Multipede) Colour Problem
48CR
Ok so I thought this might be something simple (and it probably still will be !)
Just picked up a centipede cab and it has a millipede board (with Multipede) the colours are strange - I thought it was red that was failing - but not sure (have a look at the pics). The machine passes all self tests ok and goes through the colour cycles but I get Blue / White / Yellow - but no pure Greens or Reds
I've checked continuity (as far as I can tell !) from the millipede board to the monitor plug where it goes into the G07 and they buzz ok.
the board has an arcadeshop millipede to centipede harness adapter and this seems to buzz out the colours ok.
Now here's the funny thing - the cab came with the original centipede board and the self test on this cycles all the colours fine - although it looks like it is reporting some ram errors so won't play
Any ideas on what to look at on the millipede board ??
leslie
42CR
i know you can convert millipede to play centipede but not centipede to play millipede unless you change the centipede harness for a milipede one , i could be wrong!!!
ben76
Hunts Spies
1,136CR
For the colours can you test any pcb you know that works to see if its monitor or pcb. Even if its a temp adapter to just test the video. Then work from there?
- Ben
48CR
Ok so I took it back to basics and removed the mulitipede upgrade from the millipede board and the self tests are still showing colour issues ....
Here's the board ..
And here's the harness adapter to convert millipede to centipede
So I managed to get my centipede board up and working - essentially it was a dirty rom so re-seating / cleaning did the trick. Here the centipede self test shows colours ok
And here's a pic of centipede working - ok happy days
Ok so the monitor seems ok - as in it's producing all the colours I'd expect. I've discounted the multipede upgrade as it still shows messed up colours when in stock millipede mode.
So any pointers on what controls colours on millipede ? the game plays fine and there are no beeps indicating ram errors and no rom failures in self test
thanks
Nik
smarty
Ready Player One
1,305CR
I’m not familiar with the Millipede Schematics but schematic sheet 6A in the manual deals with colour selection and video output which given you have no errors in self test would say to me that’s the page to be looking at, you’ll be needing a logic probe to check signals on the board, is that something you can do?
EDIT* Scrub the above, going from the ops and service manual the ‘EA’ text on the left side in test mode might be a bad ROM at P2 on the board. Something to check and verify first I would say.
Cheers, Mart.
48CR
prob not P2 is the EAROM for the high score saves. this was a replaced with the original when I removed the multipede board - but I'll have a look round sheet 6A - thanks !
