Missile Command A035467
Crazy Dave
1CR
Well here goes.... my first real post on the forum.... well apart from the newbie section!
I've been working through the fault on the above board and finally get through the self test mode without any errors. The game is running and I have sound.
The problem is that I only seem to have a very bad green channel on the video out, no blue or red.
Having traced through good logic levels all the way to L7, the colour ram. Here I can see good levels from pin 9 (green) but not much else from 7 or 11. The IC is also quite warm.
Any ideas if I'm on the right track and if so a source for the 90-7005 ram.
Dave
Crazy Dave
1CR
Board is now working! Video / Sound / Colour all good.
I do have a strange video effect that doesn't seem quite right. I can only see 3 lines of the score text at the top of the screen. Seems to be missing the first 4-5 lines of video?
Having a good check through now to make sure all the video logic is correct...
Crazy Dave
1CR
OK... so it looks like its a 'feature' of my old Philips CM8833 monitor... Watching RGP's repair video his MC does the same on a 1084s. Something to do with the MC board using the overscan area maybe??
RGP
Meeter & Greeter
2,039CR
lesoleil70 said:
Congrats, the RGP vids are worth their weight in gold aren't they.
I like to share what i've learned, its a journey for me as well.
I'm happy to post and help out on here as much as I can and if people want to send me things to sort that's fine too.
You've got me thinking now, i'd have to find some video or photos of the board in the cab running to ensure it wasn't some kind of offset thing and it was the overscan - although the 1084's/CM8833's are usually pretty good at displaying these.
If you have a regular arcade monitor i'd fire it through that as a final check - it would be interesting to find out if its right.
The only other thing that could be happening is that the V-clock could be starting at 3 rather than 0 - I mean that's crazy speculation but worth a quick look at Input A, B, C and D on the chip generating 1V, 2V, 4V, 8V - when the LD signal happens, whatever is on the four inputs is where the chip is initialised to, when it keeps counting past 16, it'll send the RipCarry signal on to the 16V chip and reset itself to zero.
If this was the case then legitimately it would shift the screen up 2-3 raster lines and cut off the top.
Given that both the 1084 and CM8833 are video monitors themselves and can display a full composite signal i'd say we might be onto something.
Of course, I could be talking complete codswallop but worth a quick look.
Crazy Dave
1CR
Oh yes... the videos really helped.
When the board arrived it was completely dead... No Video / audio etc.
The data-bus was a mess, with competing logic levels all over the place. I don't have any history of the board other than what I could see. It had an odd type ram at H4 (different to the rest). Missing crystal. Several broken decoupling caps. J3 had also been changed.
Anyway, end result was a permanent watchdog board without any diagnostics!
Thanks for the further tips RGP...I only have the one monitor... so I'm unable to check it out on anything else. The CGA / VGA converter card I have appears to be one of the knock off units that doesn't work correctly... so I can't try that either.
Looks like I need a cab monitor to continue, but I will have a look at the counters as you suggested.
Many Thanks
Dave
PS I'd forgotten how difficult MC is... or is it just how bad I am at it
smarty
Ready Player One
1,305CR
Nice fix
Here's a photo of a MC board running on my test setup, it had a similar cropping of the text in the top few lines of the display, it displayed fine in a proper arcade monitor, must just be the display settings.
