Missile Command ground issue (maybe)
TDE_Rich
18 (100%)
178CR
Evening all. Thoughts please...
Missile Command upright. Switched on this eve, curser goes nowhere other than up or down. Reach through coin door to unscrew the CP bolts and bzzzt, small shock from the coin door. Okaaaay. Reach up again, nothing. Start unscrewing right-hand bolt. Still nothing... until I pull out the bolt from the top with my right hand and seemingly complete a circuit and get shocked again. Nothing major, but enough to make me think twice. Have to admit, I hadn't unplugged at this stage (but the coin door being open cuts the power, so it didn't even occur to me). No shock from the left-hand nut and bolt, just the right.
Now. I changed the bezel set recently and the trak-ball mechanism sits pretty close to the right-hand bolt and also catches on the bezels, requiring a fair amount of juggling and jiggling to get everything back into position. I discussed this with Tony T. recently and he didn't have this issue. Maybe I screwed something up. The main thing I want to establish is safety, so it's unplugged for now, but obviously the monitor is holding it's load so I didn't want anything random like a voltage leak / ground issue from that neck of the woods. I'm strictly amateur so be gentle.
TDE_Rich
18 (100%)
178CR
No reading from metalwork. Unplugged overnight, opened up the control panel, gave the trakball molex a little wiggle... shocked again. Must be coming from monitor, no? Not exactly monitor voltage though. WTF?
obcd
3,830CR
Set your meter to an AC range bigger than 200V. Touch some metal of the machine with one probe and hold the other between your fingers or touch some radiator pipe with it. You will likely see a reading if the machine is not properly earthed. It can even be the earth in your wall socket that is bad.
TDE_Rich
18 (100%)
178CR
Presumably I've eliminated that potentiality by this still occurring when the machine is unplugged? No sarcasm intended whatsoever... I'm new to all this and weird sh*t happens, so it's a straight-up question.
obcd
3,830CR
In order to be shocked, there need to be a current flow. If you unplug the machine it has no need for a current flow to earth trough your body. The only exception is static electricity. You sometimes can feel little shocks if you touch the glass surface of a monitor, even after the monitor is switched off. It's usually the case in very dry environments. If your monitor chassis isn't properly earthed, the static voltage present around your monitor chassis can become higher. I am unsure if treating your monitor surface with an antistatic spray would improve the situation. As static electricity attracts dust particles, those sprays where intended to decrease this. Simply do the test with your meter. It's quickly done and can proof we can eliminate earth faults.
RGP
Meeter & Greeter
2,039CR
Ant is doing a job in London next weekend from Thursday night, I think he said he'd try and schedule a visit to you. You shouldn't get shocks if the cab is unplugged entirely from the wall though.
Any stray strand of wire shorting live to earth would pop the fuse - even a hair strand would do it as it would be a dead short.
It won't be the marquee which runs at 240v after we replaced the knackered one as that's a double earth device.
I just serviced an imported Q-bert for someone which was a death trap of disconnected earths including the ground from the tube but didn't get a zap from that.
TDE_Rich
18 (100%)
178CR
Assuming that’s not my Q*Bert!
