Missile Command Help
Purity
The Oracle
17 (100%)
2,999CR
I was wondering if you guys could point me in the general direction of what could be causing a gfx issue on a missile command PCB?
I will post some pictures when I get home tonight to assist but basically I getting some red gfx corruption that seems to affect the missile command logo at the start and then covers the bases at the bottom of the screen. Game plays fine.
Which chip could be affecting that?
I know this is a bit vague at the moment, so as I said I'll post a video and pics later.
The PCB also has a Braze multi-game kit fitted so I'm wondering if that could be an issue?
VectorGlow
34 (100%)
900CR
A RAM fault springs to mind - test mode will indicate this if so (do you have the manual to identify the any faulty RAMs via the test tones?).
Purity
The Oracle
17 (100%)
2,999CR
I've powered up the cab up. I get a low tone then a high beep which
according to the manual sounds ok. But you can clearly see the
corruption at the bottom:
VectorGlow
34 (100%)
900CR
Hmmm, Missile Command boards can be a bugger at times, so many things can go wrong with them and they can be a pain to debug. I've only ever failed to repair one though in my time (and have fixed a great many) and that one I sent to Mike Coates who managed to suss it out - that was a few years ago.
Presumably the voltages are okay and the ROMs have verified okay? Note: the ROM sockets on MC boards are well known for their dodgy contacts and often need replacing.
I guess the green tint to the display is caused by your camcorder? Would be nice to see a better picture (flat on) with good colours - also in-game if possible.
If I may ask, what test equipment do you have? Multimeter? Logic probe? Oscilloscope? etc. Depending on what you have I'd start by probing around the colour output section of the circuit and working your way backwards.
Purity
The Oracle
17 (100%)
2,999CR
Not had time to check the roms or voltages as yet. That will have to be at the weekend. I intend to get the power brick out and tighten the transformer as it buzzes like hell
The colours are a bit off so will take a look at that. The video I took should be white text on a black ground, but looks more yellow (it looks green on the camera)
I can take some in-game footage if needs be
I've already experienced a dodgy CPU socket
Yup, I've got a multimeter, and am familiar with testing voltages on Atari games. Logic probe -check. Programmer - check, Eraser - check. Oscilloscope - Negative.
Purity
The Oracle
17 (100%)
2,999CR
Went to test the voltages, but the game does not power on at all now. I heard a click, then nothing
We have a power brick failure somewhere. I need to take it out and see what I can find
I checked all the fuses quickly and they all seem ok
Purity2013-10-17 16:04:30
Purity
The Oracle
17 (100%)
2,999CR
I'm going to build a Jamma adaptor for the board so I can see if I get similar issues, and it will be much easier to work on outside of the cab. I've removed the PCB.
I've clearly got power issues with this aswell. Maybe this is what has damaged the PCB.
I'll pull the power brick out and try and get it working again, then check all voltages on the ARII
Purity
The Oracle
17 (100%)
2,999CR
I've disconnected the ARII Steve, and the power supply is dead, so the fault could be in both places, but I'll need to get the brick working first
tb lilley
5 Star
1,686CR
If you take the power brick out remember that it won't work at all if you don't also plug the AC harness (interlocks/0n Off switch etc) into the top of the brick.tb lilley2013-10-17 21:09:20
Purity
The Oracle
17 (100%)
2,999CR
The interlocks and on/off switch have been removed by a previous owner, and the socket bypassed, so the brick should work if totally removed from the cabinet
Purity
The Oracle
17 (100%)
2,999CR
Jesus I am so glad I didn't sell this to anyone!
I have found the power fault. Basically someone has just tinned a bit of wire and shoved it into the hole of the molex connector on the interlocks/switches socket, without securing it properly
and the mains adaptor is not much better
Anyway soldered new wires on some connectors pins on all the dodgy cables and we have power again!
Purity2013-10-27 13:49:54
Purity
The Oracle
17 (100%)
2,999CR
Ok, so I am back where I started. Missile Command working but with a GFX fault.
I took some measurements at the PCB test points:
+5 giving 5.12v
+12 giving 12.52v
-5 giving -8.91 when doing nothing. During gameplay upto -11
Voltage regulator issues on the ARII @Q9 or PCB fault? Next option is probably test on MC PCB out of the cab, and try the test points again?
Purity2013-10-27 17:05:37
Purity
The Oracle
17 (100%)
2,999CR
I took a picture of the 7905 voltage regulator in the missile command. See what you guys think.
Observations are that the mica is not straight. Is there a a chance it might be shorting on the heatsink, hence the high -5 voltage under load?
Also this does not look correctly fitted. It is not flush to the board (BIG legs) and hence no hole for the plastic screw to go which is missing.
I also thought the LM305 on the other side did not need a Mica and usually had a metal screw connecting it directly to the heatsink
Purity2013-10-27 18:11:42
4,058CR
One comment I will make is that if that 7905 isn't screwed in to the heatsink then the heatsink won't be taking any of the heat away and it will be overheating!!
Couldn't tell you if either of them need the insulator or not off the top of my head. If it's -8.91 without load then there's an AR fault for sure! And likely culprit will be the regulator.
