Thanks for your detailed input lix and yorkshire_spam.
I should have pointed out that I am a novice in this area....I can just about use a multimeter, Maybe the soldering iron, stare at some electronics for a period, then put it back for later. However, I’d fancy my chances swapping one chip for another on a good day. I was really looking for someone with knowledge to do it - but every day can be a school day eh?!
In a little more detail - I’ve seen a lot of video games over the years and my dad was an operator back in the day. He had Atari UR, cabaret and cocktail versions of MC...but I’d never seen a Sega cocktail. In a dusty garage I spied one, and bought 3 cocktails for too much money to get that one. No board, not switched on for decades. I did ask someone on here and it was agreed I could bring it, with the newly refurbished board I bought, to be brought back to life. This was delayed, then didn’t happen, then we’re all in a pandemic.
So, having checked voltages and fished around I thought all ok, but was reluctant to risk my expensive board first - cue good-money-after-bad, buy an ‘untested’ board from eBay. A day later, lo and behold up comes a Sega MC cocktail on UKVAC which I bought and collected happily, good deal, top bloke, no surprises. Not having been sat for decades and only recently bust, I return home with more confidence. This one, quick check of all voltages and put in the untested board and straight on to the refurbished one...bingo. New MC works great.
The same results happen with each board in both machines and voltages are good, maybe a touch low on both - 4.8v ish on the +5v. I have one fully working set up, plus a machine and 2 boards.
As I am in no rush and have little to lose.. I’m tempted to try changing the 6502 CPU you mention - though I do not want to touch the working board! If I buy one of the 6502 chips working, they are all the same? I can then check other connections I can see - but do not have any diagnostic equipment.
If you could kindly let me know if there are variants of this 6502 that I should look for and that it does not need to be programmed etc. I’ll have a go when I have some time.
Many thanks,
Jon
