Missile Command
Lurch666
4,507CR
So I got a missile command to repair and I'm making no progress so I'm posting this in the hope that either someone can point me in the right direction or making this post triggers an idea in my mind on what to do next.
It just shows a blank screen that flickers white every few seconds. It's not watchdogging and appears to be running code.
If I switch to test mode I get this screen for a few seconds:
And then this:
So it's showing the test screen but it's messed up.
All but one 4116 ram is socketed and I replaced all those,I have checked out the sync circuits and have the proper signals coming out of the 191 chips.
Ive checked continuity on the eproms and ram chips,burned new eproms,verified the prom at L6,verified with the slice the 153 chips working the drams and checked the ram at L7 with the slice and it all seems good.
Can't seem to find out what's wrong.
I figured it must be a bad frequency coming out of the sync circuit but it all seemed fine on the scope and all the chips check fine with the slice as well.
I don't have a pokey at the moment (it's on it's way) but that shouldn't stop this from working it just means I don't get the diagnostic beeps in test mode.
Any idea what could be causing the corruption of the text on the test screen or what could be stopping it from showing any signs of life when it's not in test mode?
I'm following a thread on KLOV and that's been a help and I've found plenty of info from the net but nothing has shown me where to go with mine.
Phils Arcade
1,529CR
I've seen this before. Was bad a RAM chip feeding one of the drivers, can't remember which, and the address bus driver at B1 was always being pulled low. The one stuck in the corner of the board.
If trying to run the test screen seems like the CPU is running okay.
Infurious2022-10-11 11:57:00
philmurr
48 (100%)
2,374CR
As test mode doesn't write to the bottom 32 lines of
the screen whereas game mode does I'd first look at MADSEL/MUSHROOM
generation and 3rd colour bit select
The text on the test screen looks to be in the wrong place as well as garbled so I'd suspect something in the sync circuit (or less likely the DRAM controller 157's)
The board is SLICE-friendly apart from the 4116's so you should be able to go through the above parts of the circuit fairly quickly
Lurch666
4,507CR
MADSEL is showing activity but not MUSHROOM since pins 10 and 11 of the LS11 at N3 are never high at the same time. Clock extend is inactive for the same reason.
I wrote the first part of this post then went on the check the LS157s that control DRAM.
All were working fine until I got to the last one at M2. Clipped my SLICE onto it,started the PCB up and got the words 'MISSILE COMMAND'.
YAY. Looks like one or more of the legs of the chip are fractured and the SLICE clip put enough pressure on it to make the connection.
Progress at last.
I tried the test mode and it appears fine now. It's showing ROM RAM AND MAP OK but also BAD CHIP which I assume is due to the missing pokey.
The missile command logo appears and flashes but there are no mushroom clouds. Don't know if that's down to the missing pokey or something else but at least I can now check knowing at least the board is nearly working.
Thanks for the help.
Lurch666
4,507CR
Replaced the LS157 and as predicted pin 1 was fractured and fell off.
Pokey turned up today and now it appears the game is fully working. Not checked sound or controls yet (no trackball so will have to source one) but it appears to be OK.
Can't see the scrolling text at the bottom during attract mode but that's because my test monitor has no adjustment so will have to try in my cab to verify that's ok.
So if you have a missile command without a pokey you do get the missile command logo but no explosions.
Equites
Chief Sheesher®
35 (100%)
3,329CR
Explosions should still be ok without Pokey
philmurr
48 (100%)
2,374CR
Think he means in the title screen where "Missile Command" is displayed. You won't get the explosions without a pokey as it is used for random number generation on where to place the explosion
Equites
Chief Sheesher®
35 (100%)
3,329CR
Ah interesting, like Centipede then with the mushrooms.
