Missing F355 paddle part
gr0don
110CR
I am currently working on an F355 dash, more specifically the paddle shifter that is in pretty bad shape. I have resolved the excessive movement in the shifter caused by the worn bushes thanks to Chris2922's post on here.
The other issue I am having is the paddles can freely turn 360 degrees without moving the wheel (I guess that also explains why the microswitch wiring in there is all torn to hell). On looking at shifter there is nothing to secure it to the shaft - the manual says there should be a handle collar (FRI-1203) that I appear to be missing. Can anyone tell me what this is or show a photo so I can try and hunt something down to do the job - I can't see anything online. Screen shot from the service manual should be posted below.
Thanks in advance,
Gordon
Crowds
11CR
hi mate I literally just sold all these bits to anonymouse on here (Liam) he maybe able to assist ????. Ps the screen is waiting on a pick up date
Cheers Paul
gr0don
110CR
Thanks for the help so far guys - Paul - Martin was up my way at the start of the week and I think he is planning be be at yours in the next couple of weeks - no doubt he will be in touch soon. I have plenty of work to do before I'm ready to put a monitor in this by the looks of things. If you have the wiring that would be great - its only a few micro switches so not the end of the world if you don't.
Chris - Is does that black rubber bit secure the shifter in place or is it only to protect the wires from rubbing away? I have a some pics of mine attached. It just looks a bit flimsy to hold the shifter... am I being stupid and there is something you can turn to tighten the shifter to the shaft?
Thanks,
Gordon.
5,415CR
Not sure now without looking but sure they have key that sits in the steering shaft so it just pushes down over it they called woodruff key or something like that, basically just oblong of square metal
corn
26 (100%)
231CR
99% sure that Bods has remembered this correctly. I remember there being a small milled slot in the steering shaft into which a small metal key piece fits.
Have a closer look at your steering shaft.
gr0don
110CR
Hi Everyone,
Thanks for the help so far. I had a look over things and I can see where it should click in on the rear of the shifter. However there appears be to be nothing on the shaft to lock in to? It also does not look like anything has broken off. My guess would be there is supposed to be some sort of Jubilee Clip type thing to hold it?
gr0don
110CR
Ah this must be it, I tried to post 3 photos last time but it only posted 2. Thanks for the info - I don't see any suitable sized screws rolling about in the cab so will see what I can hunt down. Thanks.
5,415CR
The white wire in 2nd picture up, that's grub screw under it isn't it?
In the first picture diagram of it all, that Handle Collar, if it's the No 2 item on it, that is just the heavy bit of Metal Tube that slots over steering shaft, where the end of plastic is from Dash around it, you see that just proud of plastic, that like the stopper for the paddle shift unit
Yeah should be a slot in the shaft somewhere for the key
corn
26 (100%)
231CR
Thats it. You'll need to make yourself a small "key" - piece of rectangular metal that fits in that slot and locates the paddle in the right place. I suspect the grub screws are probably M4 or similar.
5,415CR
yeah you can see slot in the photo you just added now, just infront of hole where wires go through shaft.
Grub screw still in the top off paddle shift under wire?
gr0don
110CR
Sorted!!!!
That was indeed the "missing" screw. Once everything was lined up it tightened nicely and the shifter is now solid and locked to the shaft. I feel a bit daft for not noticing that. Thanks for the help guys - This will no doubt be the first post of many on this cab!
5,415CR
https://www.amazon.co.uk/Parallel-3-4-5-6mm-Feather-Flywheel-Pulley/dp/B09167P54N/ref=asc_df_B09167P54N/?tag=googshopuk-21&linkCode=df0&hvadid=499292497816&hvpos=&hvnetw=g&hvrand=6447421908143170571&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1007201&hvtargid=pla-1245035998499&psc=1
Box of them on amazon, probably get them cheap off ebay, could just buy some square metal but I suspect they are hardened, measure width and length of slot
It's easy searching for stuff like this if you know exactly what they are called
5,415CR
That is what they should have as well as grub screw to lock in place but then there isn't any force put on the paddles as they turn with the wheel so home use I can't see it being an issue, I may have some kicking about, if I find one I can post one to you
If you strip the shifters apart on this, sometimes the screws can be a pain to loosen, they have locking glue on so sometimes need heating up, or use impact drive to break them loose as the heads chew up quite easy
Have you decided what to run in it yet Gordon?
Bods2021-08-23 10:43:55
gr0don
110CR
First of all it is going to be an emulation cab - I have been working on getting attract mode + the usual emulators all set up. I have also have a FFB board on order from Aganyte at gamoover so will hopefully have that in a few weeks.
Long term though I think OR2 is looking most likely. All the wiring is going to be correct and left in place, I have the Chihiro already but the cab needs a load of work to get it looking good.
gr0don2021-08-23 10:55:36
