Mixed transistor / cap / resistor sets
Nes4life
1,134CR
Can anyone recommend a source for sets of mixed transistors, caps or resistors? I've seen a few on eBay but worth checking if anyone knows sets suited to general arcade repair.
I've been buying multiples of parts as I needed them but just wondered if anyone bought sets in advance of needing the parts.
Oh yeah... my current needs are an A1015 transistor and a small orange flat disc shaped cap (the kind used between ICs & ground).Nes4life2016-03-09 08:00:17
jengineer
49 (100%)
1,205CR
maplins do some small sets of resistors etc but they'll never have the exact value of the component you need
you'll always need to buy the parts in, if you repair a lot you'll end up with a vast stock which always comes in handy
OTTOTHEMADANDEVIL
Will gyrate for Gyruss
328CR
What value are the orange caps?
Battlezone
410CR
Battlezone
410CR
The small flat orange caps that you mentioned are typically
0.1uF or 0.01uF (aka 10nF or just 10n) ceramic disk/plate
capacitors, and are power supply decoupling caps (to eliminate
noise).
They need a voltage rating that covers the power rails you
are putting them across. That's often 5V (so buy whatever
they make above that value, typically 50V or 100V).
Look for wide temperature ratings and long life times if you have a choice.
Battlezone2016-03-09 13:54:33
