Model 3 rtc battery
PhilT
154CR
Anyone know where the battery is on a Daytona 2.
I have been rewiring and when I start her up I get a message:
low battery.
rtc battery voltage is less that 2.65v. Press start or test
I have had the cages open but didnt see a battery. I am assuming it will be a watch-style one.
The Daytona 2 manual make reference to the battery but does not say where it is and then helpfully says Sega will handle it!
Vamino
Insert coin(s)
2,698CR
The battery is a CR2032 which will be located
on the CPU board hidden underneath your security board on a Daytona 2 stack.
The photo below is of a Scud race stack which doesn't have a security board so the battery is visible, the battery is located at the bottom right hand corner just above the 6 leds.
PhilT
154CR
I got around to changing the batteries on my Daytona 2. For reference in case anyone else needs to do this for the first time, the battery is not under the security board, its actually under the communications board. Take the comms board off, change the battery and put the comms board back on, job done. Leave the security board well alone...
The reason is that if you undo the bolts holding on the security board, you will release the non-captive nuts on the underside of the cpu board which will then drop off and sit on the video board ready to cause havoc. You wont be able to retrieve them or re-tighten them without taking out the entire stack.
I used this unexpected opportunity to give the boards in the stack a good clean as they were filthy but its not something I had planned on doing!
