Bit of an update here, hot air station arrived and have been having a bit of a play around with it. Have replaced the 2 srams nearest the battery, which didn’t seem to make any difference, and replaced the Ram chip ic17 on the CPU board, this one was showing as bad in the test screen and is now showing as good; however, this hasn’t improved anything as far as I can see.
I did also spot something which may be the cause of these on going issues, when the stack was on the worktop minus the rom board I noticed the pcb legs didn’t seem to be sitting flush on the worktop, with additional weight of the Rom board all the legs sit flush, I removed the middle leg supporting the centre of the stack and it looks to be fractionally longer than the other PCB legs.
This post supports the board near ic62, which according to the Australian fellas guide is a depth buffer ram and its failure can cause horizontal lines through some textures, which is the issue this stack has always had.
With this post removed and light pressure applied to the board, the texture issues disappear.
My thinking is perhaps this longer post had applied pressure to the chips on the video board and upset the solder joints, with the rest of the pcb legs bolted down securely, even the slight difference in height could flex the board, unfortunately reflowing the pins on ic62 doesn’t seem to have made any improvement so I don’t think it’s an issue with the pins, there are also 2 bga’s relatively close and I’m now thinking that perhaps they have contact issues, that would explain why the board seems to boot fairly reliably when its warm, but takes many attempts to boot from cold, but I don't think there is any way I have the skills to fix that.
Kev A2018-12-17 13:46:45
