Money Controls Hopper Question
lowlevel
69CR
I have a horse gambling game and would like to change it to euro's. It now works on old Belgian FR (50Fr)
For reference:
50fr: 22.75 mm diameter
1 euro: diameter:23,25 mm, thickness: 2,33 mm
I has the Coin Controls Universal hoppers with standard belt/window.
From the coin controls manual it should work with coins from this size:
Standard
Model 1.25 - 3.5mm / 21 - 30mm
Small Coins
Model 1.25 - 3.5mm / 16 - 21 mm
Are these generic in a way that it will pay out coins that are in the same margin?
Or does it take other steps to make this work.
Also I have this hopper as a spare. This is from Money Controls, pinouts looks the same, but can someone confirm this is 'plug n play' compatible'?
From the manual (table attached), these hoppers seem to have a coin margin
lowlevel2019-01-07 10:16:12
obcd
3,830CR
Yes, it should work and both hoppers should be compatible with each other. (But you figured that out already.)
You should be able to program the coin acceptor to accept euro pieces as well. (Depends upon the type installed)
lowlevel
69CR
Thank you for the reply and for the hopper confirmation.
I have coin control comparitors CC-40 and I replaced the old coin with a eurocoin and all works now.
lowlevel
69CR
Hi Obcd, nice to seen Belgians here
It is, but it was brown/black dirty... now shaping up pretty nice!
Don't happen to know a source for a pcb (ide connectors type) for this machine?
I have another one of these with a dead pcb unfortunately.
lowlevel2019-01-08 14:13:48
obcd
3,830CR
We used to have a couple of those in our arcade. I can't remember if it was GAA or NAMUSCO who sold them. I seem to remember the pcb had to be changed once to comply with the Belgium protocol for the commision. If yours are the newer type, they should have a pcb between th game board and the right keyboard if I remember well. I don't even think it was allowed during that period to be a dual player game. The left keyboard was disabled if I remember well.
lowlevel
69CR
Correct it was GAA, also Wimi I think.
Questions have been asked, waiting for reply.
I remember them starting in Belgium as a double player, then being forced by government indeed to only operate as a single player.
The doubles had this pcb combi E06-00409 + extension board E06-00407 (for p2)
The newer pcb is E79-0001 and operates both sides.
