Monitor blew up...
chubsta
547CR
Got a new cab today, plugged it in whilst sat at the back of the machine with the back door open, just in case something happened, and it did - there was a loud fizzing noise, a bright red glow from a big white component on the monitor chassis - the bit the red wire comes out of to go in the back of the monitor - a little pop and some smoke and my monitor was dead
the chassis is an electrohome G07 -so, options?
Mitchell Gant
888CR
Sounds like the flyback transformer has failed, ouch! Could have damaged other stuff too sadly.
Must be a bad night for GO7's I had an enormous arc flash out from under the anode cap to the scan yoke tonight on one , now it's died even more than it was already. And I was hoping it was close to working too.
G
Guests
Guest
You're options are
Either -
1. Replace the flyback and other failed components yourself
2. Send the chassis to Ordy or Gunblade
3. Replace the chassis
4. Replace the monitor
Nasty failure that!
chubsta
547CR
PAC-MAN said:
You're options are
Either -
Nasty failure that!
all packaged up and off to Gunblade tomorrow morning!
Any idea what could cause the problem - the reason i ask is because i dont want it to be fixed, only to plug it back in and then blow up again when in the cabinet... what can i check prior to refitting it - it seems like there is only really the 2 wires for power and thats it...
the cabinet was delivered to me at about 8.30pm, and i plugged it in at about 10.30, although it had only just been dragged down the corridor and put into the room a couple of minutes earlier - should i have waited a few hours after moving before plugging it in?
chubsta
547CR
pulstar said:
Oh dear, that wasn't your Joust was it? Hope the Lordsvale's been ok for you.
Dont get me started on the Lordsvale.....
only kidding, very happy with it - havent got a game to play but the test pattern came up ok and looks lovely!
G
Guests
Guest
I'm no expert but as far as i'm aware the flybacks are wound with fine wire. These dudes do work hard and in the end the windings fail and short and in most cases fail due to themselves and when they do go can take other components with them like the H.O.T etc
RGP
Meeter & Greeter
2,039CR
Personally I think the thing about moving and then leaving cabs is a bit mythical. If you've just received a machine you've bought, open the back, look for loose wires, check edge connectors firmly seated, ensure nothing fallen on the fuse block shorting things out. Freebies like loose change that slipped through the coin mechs 30 years ago and sat in the back can cause tons of trouble.
I move mine about quite a bit at home but new arrivals get scruitineered just because things move in transit. When I take machines to shows, always repeat the checks.
Chips on PCBs in sockets are the common movement.
Lets see what Grant has to say was wrong with the chassis, do let us know.
forcefulfil
EDOT King
17 (100%)
1,675CR
Sadly i sold Chubsta a Joust with a re-capped/re flowed GO7
ive had hrs of play test etc to eliminate re-sets etc etc and it did pass them all.
Im gutted it died on test
but sadly flybacks do get some heat and go brittle and can crack when being transported
i have offerd to repair this as part of our deal free.
i know sh*t happens and ive had things smoke upon arrival too,but thats shear bad luck on both sides
phil
chubsta
547CR
phil
I didnt want to get into any 'blame stuff' as its just about getting the monitor fixed but just so there is never any doubt or confusion for anyone else reading this -
In no way do i feel i was sold a pup - this is just one of those things that happens and is all part of this wonderful hobby. I always buy stuff with the assumption it is working when it leaves someone but will not work on arrival, if it does it is a bonus! As explained to my other half, this is not a component that has blown up before and still been passed on to me, these boys only go once and then they are gone, so am very happy that Phil sold me a working machine, absolutely no issues there.
I have just received a message from Phil offering to fix it for free which i feel is above and beyond his role as a seller so will take him up on this rather than send to Gunblade, who although i am sure would do a good job can't really compete with 'free' when it comes to pricing
trm
2,877CR
Phil is a star!
The only thing I'd let settle for a while after moving is a fridge or freezer due to dissolved gasses in the coolant. For cabs it's just checking as others have said that nothing has worked loose, or acclimatising if you're moving across a large temperature gradient.
RGP
Meeter & Greeter
2,039CR
trm said:
... or acclimatising if you're moving across a large temperature gradient.
+many on that. If you receive a cab known to have been transported from a warm environment, stored in transit, maybe in not so warm, and then brought into the warm, i'd let it breathe a bit in its intended environment before putting power to.
For those that have cabs in their garages, the neck and flyback of the monitors are usually up against the outside wall which will likely be far colder than the center unless it's a well insulated space. While cooling is definitely good for components, they have an operating temperature and get warm quickly. The cycle of hot in use, cold in store leads to expansion and contraction of the item and shortens its life a bit quicker than we'd like.
gunblade
9,096CR
the g07 flyback is notorious for cooking,when they go they go with some noise and smoke-they tend to split
i would suggest any g07 owner gets himself a spare flyback
very nice monitor when working
5,653CR
^^^ what he said! G07 is my favourite monitor.
