Monitor Chassis ID please
smarty
Ready Player One
1,305CR
Picked up a cab today and it has the chassis below installed, Its made by Hanterex but can someone tell me what model it is please.
Cheers, Mart.
smarty
Ready Player One
1,305CR
Thanks Dunc,
I didn't say it was faulty... Well its got Raster and didn't smoke when powered up, I just need to put some video into it.
So whats the issues with these then? You'd say a cleanup and capping isn't worth it?
Cheers, Mart.
jengineer
49 (100%)
1,205CR
ah good that its working,
well no they are worth repairing I suppose, at least then the cab is original, its just that everyone of those that I've picked up all seem to have corrosion over most of the chassis, especially around the fuse area,
I have one of these that is arcing at the neck board and the screen flickers, I didn't bother buying a flyback and cap kit for it because of the issues above but each to their own dude
not sure if the flyback is hard to get?
jengineer2015-04-21 21:13:05
PaulSwan
ZZZ
1,118CR
Yup, an MTC-900. I wouldn't go quite as far as saying it's not worth repairing - these days all chassis are a worth a shot at repairing. Cap kits are readily available (if it needs one - try it and see first).
Their lifespan is bounded by the LOPT that is no longer available (hasn't been for years).
jengineer - the arcing on the neck board maybe either the focus sink resistor or focus pot is open on the neck board or the bleeder on the HV cup has failed. The latter can be replaced on this style LOPT.
Paul.
tb2000
3,578CR
They're still a half decent monitor chassis. I repaired a 14" one ages ago on which I put a new HR lopt and a full cap kit (I also changed the tube as it had a shadow mask/purity problem I think) - had probably the best picture on a 14" i'd ever seen - certainly easily on par with a Polo chassis.
tb20002015-04-21 22:52:39
RGP
Meeter & Greeter
2,039CR
Paul's spot on, i'd always give repairing one of them a shot, from what i've experienced and what i've learned, the HV side doesn't die that often on them similar to the 900/E, however, the focus pot on the neck can go bad and drift when warm and I haven't been able to find a suitable replacement yet.
bbz149
26 (100%)
1,608CR
Had one of those in my Tron. Focus pot on the Neckboard was forked, Connections to the Tube are crap, HV Cup that connects into the Tube go hard and don't sit right. Scrapped mine after Craig gave up repairing it. Stuck a better 9000 into Cab
PaulSwan
ZZZ
1,118CR
Yes, I remember Craig saying that the 900/900E/9000 all use the same yoke. If you decide you don't want the 900 chassis I'll take it off your hands - I'm always on the lookout for spares :)
You can use a heat gun to reform the HV cup back into the right shape.
Paul.
tb2000
3,578CR
Yoke is the same yes, but I'm not sure on the neck. The pinout is different I think on some with a different design neck plug/socket, it was in the case of the 14" tube I had to use anyway. More like a 12 pin neck. There's three different neckboards though I think, so you'd need to check.
