Monitor Earth Strap
DABYX
109CR
Hi guys,
My Electrohome g07 suddenly started arcing like crazy whilst I was trying to see what's what with it.
I assumed I wasn't putting the anode cap on well enough, then thought maybe I wiped off some sealant.
Since then I've stripped the cab and putting it back I saw the earth strap was a rusty mess and it broke in my hands.
So gonna refit a new braid when I can. However finding decent pics of how it should be done is difficult.
I have a couple and some bookmarked forum descriptions but just wanted a hand on here.
So anyone have a few pics or some advice on what to use/how to strap it.
I'm sure I could manage but talk to the experts ;)
Cheers!
DABYX
109CR
Bump for reassurance.
If I were to buy 2 of these,
Braided Wire
and have them both halfway across over the dag but nut n bolted together, would that suffice? DABYX2015-10-21 17:21:41
gunblade
9,129CR
the braid should cross the tube below the deflection coil and well away from the anode,it should bolt to all four frame fixings and then you can strap a neck card wire to the braid(twist around the braid and solder)
a photo of your actual tube would help tbh
DABYX
109CR
Oh right sorry!
I've since had a.proper look and can see where the previous thin metal strap was attached. From top to bottom corner, away from the cap and tightened with a spring but not all 4 fixings? So was gonna go with the same but using braid.
So soldering the neck wire will suffice then?
One long braided wire should do it then.
Dont have a pic on hand but will probably triple check once I get the stuff sorted!
That arcing scared the daylights outta me!
