Hello all,
Had a monitor go down last night, my 9000a the only one which has never needed a repair, until now.
Right here goes, easy for some of you I'm sure, please try to help me quick as I'm itching to get it up and running, I had just put Ghost's and Goblins in there a few days ago and miss it already!
Classic 9000 series style of fault, picture goes then I can here a faint crackle/bubbling!!
When I checked the large white resistor was soooo hot it was almost on fire, you could see the outer core of it was melting, and yes I had to touch it and it was very hot!
So like all 9000's and following the repair logs for these LOPT and HOT.
Just now I removed the LOPT and sure enough it has a dirty great big crack around in and something has oozed out
not sure of the technical term there....
So my question is this, I have another LOPT from a 9000 (but not an 9000A) and I know I can use this IF I cut pin 2, question is which pin is pin 2?
Lastly does this only apply to the HR replacement ones, as mine seems to be an original 9000 LOPT
(But I know this one is good as I removed it from a fully working 9000)
The part no.?? on the broken one from the 9000A is:-
072-011 1E2109
The part no.?? on the one I have to go in as a replacement is:-
072-011 1F1036
Is the last bit a batch no. and it won't matter or is it all a part no. which needs to be the same??
Just for ref the one that's was in the 9000A (with the crack in it and is broken) has all it's pins intact no-one has cut any of them.
Sames goes for the 9000 LOPT
Please help
Any advice is warmly welcome!
Rav? TB2000? Tim? Ordy? 69er? Ace? Zektor? P-man? (I forget who's on which forums)
One of you please save my evening!
I could have this back together in a matter of minutes, I have a HOT ready to go in, just need a nudge to know whats right and safe!
Thanks y'all
paulcan692011-04-26 20:09:22
072-011 1E2109
072-011 1F1036
Please help
Thanks y'all
