Monitor Horizontal not going down fully
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
I have a MTC 9000 monitor and The Horizontal Width does not adjust down fully using the remote board
The Width coil has glue on it so cant be adjusted
I hear a faint hiss/buzz from the monitor when its on other wise picture is great
could the remedy be a new flyback or just a cap kit or do I need to change the width coil on it
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
I would say 2 or more I can adjust the horizontal position and when I centre it the picture is overscaned horizontally by about 2-3cm either side silverfox07862014-11-30 14:26:48
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
gunblade said:
there is a cap in the flyback area that causes that issue,think it c42
thanks for confirming this
I just saw a thread on J+ by hektik that mentions the same thing
I have brought a full cab kit of 24 caps so will go ahead and do them all
one last Q.
C42 is a Plastic package Electrolytic cap, can I use a metalized Electrolytic cap to replace itsilverfox07862014-11-30 16:21:37
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
Thanks mate I thought it would be ok
took the monitor chassis out to look at it and its had work done in the past but a very very past as it was caked in soot
I gave it a wash and am so glad I did, its almost impossible to see but the hissing is explained
the flyback is the original flyback dated 1989 and has almost invisible cracking so a flyback change also needed
I have a spare parts chassis that has a replaced flyback from about 10 years ago by craig so I will use that one
