Monitor ID and servicing help.
Hi there,
I have a cabinet that I got for free from work, and it's working but the monitor needs attention.
First of all it won't sync unless I adjust the horizontal position until the picture goes off the screen at the right, and also it needs the convergeance calibrating.
I'm assuming that perhap a re-cap might be in order to solve the first issue, although the machine will most likely be less than 10 years old (was a generic Jamma cabinet, my work had 3 of them built), and if so I was wondering if anyone could ID the monitor from the attached images
gunblade
9,136CR
its a wells gardner k7000 series
it may be a 25" crt but would need the tube number to tell for sure,actually looks like a zenith tube-hopefully not a zenith chassis
gunblade
9,136CR
yep its still a k7000,even tells you the actual model 25k7191
25" k7000
its not a zenith chassis
btw interestingly you have some big ol sync linking going on which probably why the picture will not lock correctly
last photo connector plug should go red/green/blue/ground/nc/nc/key/nc/nc/comp sync
nc=not connected
key=keyway
25" it is then...
What do you think the best way to proceed with my sync issue is?
EDIT: Just saw you posted while I was getting a photo, I'll do a bit of investigation from the info you've given me, ta!
Mr Margaret Scratche2015-10-24 17:37:43
gunblade
9,136CR
yeah remove the links from the video input connector,most game boards using wg chassis only require composite sync connected at pin 10 rather than all the links you have
pretty sure in the distant past i remember some midway games,possibly snk needing those links
this next diagram will help,composite is -h sync btw
http://www.wellsgardner.com/pdf/Board/K7000_13_19_25_and_27_inch.pdf
Snipped the join between the last two, the others are just connected to the earth so I'm guessing they should be fine.
Had a quick look yesterday, and all seems to be fine, but then I can't remember the exact symptoms previously as it's been a while since I powered it on.
The images is too wide, so I'm going to hunt down some adjusting tools (I can't seem to find anywhere that sells these in the UK, any ideas?)
I also have an intermittent problem with losing colors, but I found yesterday that with the connector not pushed fully home I had RGB, so I'm wondering whether it's just oxidisation on the connector/pins, rather than the pins needing a re-flow.
So yeah, once the image width is (hopefully) fixed by adjusting the coil, I'll look into sorting the convergence :)
LAZORIAN
260CR
If you don't get any joy with the coil maybe some software like powerstrip will help as you can adjust monitor size & position with it.
