Monitor Ident
bonehead
I'll get pix tonight
50 (100%)
1,729CR
Hi all, just fired up my new space harrier and the monitor is dead. It is a 100v monitor. I would like to get it going again. Any idea of model and make? Who can repair these or does anyone have a working chassis i could swop it with please?
karlcdoe
887CR
That looks like the 'standard' Nanao you'd find in a space harrier or enduro racer, if it has a flatter/squarer screen (TM) then it's a space harrier dx otherwise a more standard flavour or some similar chassis. Probably something like a 2030-s, there should be a label on the tube with the model number for the chassis on it (I think I can see it in your photo?). The flyback is/was available from Technotronic dimensions but it was fairly expensive.
How dead is it? I had several of these at one point. If it has vertical collapse then in my case it was a bad cap, if it powers up for a fraction of a second and shuts down it might be overvoltage protect/shutdown (was the vr for voltage adjust) , if the chassis fuse has blown (think there are two but check schematics) it may well be the flyback (again, was in my case). You can get away with an incandescent lamp for dummy load testing with flyback removed to see if rest of circuit is running about right.
One of Ken Laytons repair guides on KLOV forums covers this in some detail.
The picture is quite nice on these monitors when they are set up correctly so it's worth saving if possible as also they have the remote degauss switch and 100v means you'd really want to hack in an extra 120v transformer if you stick something more common in.
karlcdoe2014-03-20 02:30:40
