Monitor Identification Help Please!
LAZORIAN
260CR
This is the monitor from my Phoenix cab which I am going to recap, I think its a WG K7000 but wanted to check with some of you more knowledgeable types first in case it was something different.
At least I think it's WG not one of the Zeniths (the tube has a WG sticker on it as you'll see but I can't see a model number on the chassis).
Any help appreciated, thanks :)
ianski2015-04-09 19:53:18
LAZORIAN
260CR
Great, thanks for the help jengineer
hmm maybe it doesn't need recapping but probably won't do any harm.
I'll probably replace the flyback too as I've read bad things about the type I have.
I might expand this post if things don't go according to plan.
Cheers.
LAZORIAN
260CR
gunblade said:
is it working?
is the picture good?
leave it alone-worry about the flyback when it fails
It does work but has various symptoms...
It usually takes 5 minutes to warm up and for a while I get a decent image, albeit a bit curled downwards on the right edge and slightly wobbly. After a while it normally goes more and more fuzzy until it's well out of focus, and if left for a while longer the picture will start rolling down the screen.
I figured on shotgunning it with new parts and seeing if that does the trick, if there are still problems then I can concentrate on faultfinding. I know what you mean about the flyback though, I can't see any cracking or oozing so maybe do the caps first and see what happens.
I can post up some pics if needed.
Thanks.
gunblade
9,116CR
if its going out of focus then it is most likely the flyback causing it
other possible causes are,
bad focus pin connection in crt socket
failing tube
the symptoms you describe in relation to geometry could be capacitor related or could be an adjustment to 50/60hz pot and a suspect vertical hold pot
i bet there are a few tiny cracks on the flyback,you will only see them when it has been removed
