Monitor Interference From Lighting Ballast
6,091CR
simonden said:
big10p said:
Aren't these available in the UK, then?
Not that I could find and have been looking for ages. These are sent from China.
Smallest I find in UK was 2ft.
I may have to order from China, then - cheers. I've tried some LED strips, but they look way too 'spotty'. Tried to defuse the light, to no avail. If I can't find a decent LED solution, I will go back to using a flourescent tube.
obcd
3,830CR
I assume it depends upon the marquee itself if the individual led's are visible or not. A way to make it better is placing 2 led strips above each other so that the led's from the one shine in between the leds of the other. A led TL is basically also a ledstrip (it's just not a flexible pcb) combined with a very small voltage converter. Some of the larger ones have multiple leds above each other. Maybe not all led strips have the same radiation angle, and that can make a difference as well.
6,091CR
I forgot to say, I ended up painting the inside of the marquee area white and attached the LED strips to the base, pointing upward. This gets rid of the 'spotty' effect, but the marquee isn't illuminated as strongly as it was with a fluorescent tube. I'll wait until I get my new marquee to see if it's bright enough for my liking.
6,091CR
simonden said:
Agree with OBCD, had this in a couple of cabs, magnetic interference. Removing the ballast and using Cool White LED strips looks fantastic.
I use these instead of 12v one's though. That way you can use the existing wiring and mounts already in the cab and it doesn't matter if the cab is 110v or 240v as the input range is 110-277v. You want the 6w version for the right length.
Edit: Add link
http://www.ebay.co.uk/itm/231530845842
EDIT2: Although I don 't like those cut to length 12v strips. We have those in the Defender (was like it when we bought it) and I don't think they look right. The light looks very 'dotted' instead of one solid light. Gonna pull them out and put in some terry clips and a T8 240v LED bulb instead.
Sorry to dig up an old thread, but the above link is now dead. Anyone got a link to where I can buy these?
[edit] Found these on ebay which are "200 lm" luminosity - whatever that means. Not sure if they'd be bright enough, but I guess I could link 2 together?!
http://www.ebay.co.uk/itm/LED-Low-Energy-Under-Cabinet-Kitchen-Lighting-Linkable-400mm-Tubed-Light-Strip-/170776454246?hash=item27c311e466:g:WaQAAOSwxH1T-vge
big10p2016-05-11 18:05:27
6,091CR
dj_yt said:
The CPC link I posted on page 1 still works.
Yeah, cheers - I just wanted to see if I could find them a bit cheaper.
Is there much difference between the two you link to? Where did you get the power cables from?
dj_yt
787CR
The power cable also came from CPC.
The difference between the two is your preference as to whether you prefer cool or warm lighting. Same as standard light bulb!
bomjac
453CR
My Sinistar with LED fitted looks ace. Simply run 2 wires up from the PSU 12 volt line and you are done. Think I paid about £25 some 3 years ago for 2.5m, probably enough for 4 or 5 cabs. Price is around £15 now. Be sure to use warm white, and at 36 watts per strip it works out at about 1.2amps per metre used.
LED strip
Sinistar LED'd
5,414CR
I would just try putting some ferrite rings around the cables to the light or something like that, had to do that on machines at work to stop it knocking them out of service
obcd
3,830CR
If it's magnetic interference between the ballast and the monitor, a ferrite ring won't help.
We had some machines that generated credits on their own, but that was only when the starter was igniting the tube. We found out when the tube became bad and started to flicker.
bomjac
453CR
I disagree buddy - cool white is the worst possible light to use. It is a horrible blue-white colour. The normal colour used for a fluorescent is daylight. I had cool white led in my kitchen and changed them out for warm because of the garish blue light they give off.
But each to his own!
cosine
14 (100%)
595CR
I agree with this, I replaced the dying balast in my Turbo Outrun cab with a cool white LED setup a few years back, and it doesn't look as nice as warm white. I keep meaning to replace it, but I'm lazy.
obcd
3,830CR
A cabinet billboard is not the same as a kitchen. I agree for a kitchen warm white is what you need. It's also what you find in most (non specialised) shops.
To my knowledge, a new cabinet was delivered with cool white fluorescent tubes.
Not all led strips are alike. Maybe the cool white ones that where used in the Turbo Outrun Cab simply produce less light than the (originally replaced I assume) warm white fluorescent tube and that's why the final result isn't as good. There is a disadvantage with led lightning that you sometimes can see the individual light points trough the billboard, but cold versus warm doesn't make a difference for that. Some replacement led fluorescent tubes have a non transparant cover to avoid this.
obcd2016-05-12 12:51:41
iamjimmi
498CR
I found another ebay link for these.
Clicky
They are so cheap, I bought all 3 of the frosted types - warm, cool and natural.
It took a while for delivery but well worth the wait. The light from all 3 is superb - I can't say which I prefer.
No interference, run nice and cold and you can't see any of the LEDs behind a marque. And they fit into the existing bulb brackets and use standard T8 connections.
6,091CR
Clicky
They look good as an easy replacement for a fluorescent bulb, but I'm after something that allows me to ditch the ballast completely. I've ordered a couple of the ones I linked to above, which are 240v and come with power cable and a link cable, so if one isn't bright enough, I will mount the second one directly above it. I'll report back when I have them fitted...
iamjimmi
498CR
big10p said:
Clicky
Just for clarity, the ones I linked to do not require a ballast. Hope your solution works... Let us know...
6,091CR
iamjimmi said:
big10p said:
Clicky
Ah, OK - my mistake. I'm hoping using just one of the ones I'm getting will be bright enough, as I want to fit them to a couple of cabs. But yeah, I'll report back when done.
