Monitor issue - video - tap screen ok
bud2
24CR
Hi,
I do have another thread running at the moment about a vector monitor -- why is it always monitors !
I am just coming to the end of my MsPacman resto.
Everything was working fine previously.
I fitted the loom etc and powered her up.
Now the monitor picture is kind of squished in the middle. If I tap the screen it goes normal.
See video for fault :
http://youtu.be/zXyCvy3h8uk
I mean it looks like a loose connection but everything is tight so any suggestions would be appreciated.
I just removed the chassis and reflowed anything that looked suspect, still the same.
I thought it may be a dry joint.
bud22016-06-25 17:56:26
big10p
Coins detected in pocket!
6,087CR
That's an odd one. What monitor is it? Something on the fritz in the vertical deflection circuit?! I'm sure gunblade/tb2000 will be along shortly with the answer.
Maybe check the yoke wires coming from the chassis are well soldered. I've had those come adrift before.big10p2016-06-25 18:19:48
