Monitor issue
J69
281CR
I've turned my Afterburner on for the first time in a few weeks after it had been stored in the garage. Picture worked fine initially. Turned it on a 2nd time later tonight and no picture came up on the screen. I reset it and I got a picture but now it's shrunk about 25% and has a 2in black border on all sides.
Any ideas where to start?
J69
281CR
Still haven't had time to pull it out but the issue is consistent now.
-The image has shrunk on the screen
-The image wobbles slightly
-The brightness has dropped
-It takes 30seconds+ from turn on to see a picture
Any ideas as to what would cause all that?
J692019-12-21 15:37:01
J69
281CR
So the monitor is a Hantarex MTC900e
I've found the B+ adjust pot but where do I take the voltage measurement from on the chassis?
I've had a tweak with the pot both directions and it hasn't made any difference but it would be good to know what voltage I'm meant to be getting?
J69
281CR
Should be 126v-ish according to the manual.
Any ideas why it would be that low? And why adjusting the pot makes no difference?
Any monitor savvy forum members in the North East who can give me a crash course in fixing a chassis? Happy to pay for someones time
J69
281CR
You fancy giving it a joint go sometime in the new year? I'm bummed I've managed to get it in the house for the first time in 3 years and it's goosed before I get 1 game on it!
tb2000
3,584CR
If it's a euro 900/e then it's 126v for the b+, if it's a USA 900/e then it's 115v I think. First thing I'd do is to disconnect the b+ from the deflection PCB. You can do this by finding the red and brown wires that go from the rear of the PSU pcb and disconnecting them from the deflection pcb. Make sure you note which wire goes where. Then get a normal 60w or 100w 'proper' light bulb (not led or anything), and connect to the PSU wires. Test the voltage, if it's right then the fault is on the deflection PCB, if not then you have a PSU fault. If you want to bypass this test, try changing the three small caps in the PSU at the rear of the PCB. Or if you like you can pull the chassis and send it to me. :)
  • Like
Reactions: J69
5,332CR
Of course. Need to pay a visit anyway. Can you get cap kits (to save me time making one up)?
J69
281CR
Thanks buddy. I'll see how far me and John get, and if we bugger it up I'll give you a shout! It worked fine the last time I used it
