Monitor issue
Danscu
254CR
Hi guys
Recently the picture on my Hanty monitor in my Big Buck hunter cab had a reduced screen width for some reason.
So I tried adjusting the width on the remote board and I ended up with just a bright horizonal line on screen. I think one of the pots may have become loose.
I then noticed the final pin on the neckboard is bent back, probably from when I was swapping chassis so I'm assuming that is the fault. I tried straightening it back but with no luck as yet.
Can that be corrected or is it hasta la vista to the tube?
Any ideas?
Dan
Isgoed
47CR
I am not sure, but when the remote board is not plugged in, you also get a horizontal white line on screen?
You might check first if the board is plugged in properly and/or has a good connection.
Danscu
254CR
Thanks, when not plugged in I still get the horizontal white line.
Dan
Copperband
72CR
Did you ever get this sorted out Dan?
I'm wondering if I have a similar issue as neither my screen or remote board seem to be working on my Naomi Universal. Screen is blank and if I play a game with a monitor I have to control the service menu from the back of the motherboard instead of the remote board?
