Monitor issues
Eddy999
11CR
Hi guys.
The monitor in my first cab has some issues that I'm going to resolve.
It's an ex virtua striker machine, nanao ms8-26 maybe?
The first problem is it won't come on at all when cold. I have to power the machine for around ten minutes and cycle the power to get the monitor to turn on.. A cold solder joint perhaps?
The next issue is the focus is wrong initially but slowly comes into focus over another ten mins or so. Related to the power on issue perhaps or something else? The focus control works fine when adjusted. After this the monitor is fine and runs without issue with a great picture for hours.
Any advice appreciated.
Eddy999
11CR
An update on this.. The monitor performed much better when the cab was moved inside from the garage, the temperature clearly making a difference. There were still issues though, sometimes it would power on for ten seconds then shut down (with multiple power cycles to get it to stay running) and other times it would have a black screen immediately on power up.
The good news is the issues are now fixed. I completely recapped the chassis and reflowed a few suspect solder joints. It now powers on immediately and stays running first time. A little daunting working on a crt for the first time but a great learning experience.
