Monitor keeps flashing bright
big10p
Coins detected in pocket!
6,092CR
I have an MTC 9000 monitor that keeps flashing very bright, so that the raster lines are visible. There's also a blue tinge to the screen when this happens. Even if I turn the screen pot fully down on the lopt, the screen still flashes and shows the raster lines.
It's as though there's a loose connection somewhere, or maybe a dry joint. I've tried re-flowing the lopt pins and the neck board socket, but it hasn't helped. I've also checked the brightness preset pot.
Anyone got any ideas what to check, please?
Thanks.
big10p2017-08-15 15:43:09
big10p
6,092CR
Thinking about this, I guess some voltage is intermittently going too high - does that sound likely? I checked the B+ and it's a solid 130v, even when the screen goes bright.
big10p
6,092CR
Ok, to rule out the fault being with the tube (thought something might be shorting on the yoke or inside the neck - just clutching at straws, here!), I tried it with a known working chassis, and it's fine.
Could the problem be the lopt is on the way out, or do they just stop working completely, when they pop?
tb lilley
5 Star
1,686CR
Had a similar issue a while back after replacing a LOPT. f**ked around with it for weeks. Until I eventually discovered I hadn't bothered to solder up the LOPT's ground pin. No idea how I missed that. Was snug enough fit for it to be grounded anyway most of the time. But when not, massively over bright screen. Anyway - check the grounds. Possibly even the neck card ground too.
big10p
6,092CR
Thanks for the tip. I'll check it out.
big10p
6,092CR
I re-soldered the ground pin on the lopt and neck socket, and checked the neck board ground wire is solid, but still no joy.
If you look at this pic (ignore dark horizontal bands - that's just my crappy camera) with the lopt screen pot turned quite low, when it flashes bright, the game image stays dark - it just looks like there's a bright blue overlay on the screen, with the raster lines.
Pretty much at a loss as to what to check next, really, so any help would be much appreciated!
obcd
3,830CR
Maybe it's the blue drive transistor going bad. If the blue color is fully driven, it can cause such behavour as well. You could try the chassis with the blue drive transistor removed. Also check the color gain and bias adjustment potmeters. A bad contact in one of those can cause such behavour as well. (Rotate them a little and check what happens.) A broken focus / screen potmeter assembly can also cause such behavour. It's a voltage divider circuit. If the connection to gnd disconnects, you get maximum voltage on the focus and screen wires. On modern lopts, the screen and focus voltage adjustments are integrated in the lopt. Not sure how it is with the MTC9000. If screen or focus voltages are way to high, the xray protection should switch off the chassis.
big10p
6,092CR
Thanks for the help, guys. All the pots and drive transistors on the neck board have been replaced fairly recently, and I can't spot an issue with any of them. I've tried jiggling various things - including the 2 pots on the lopt - but this doesn't seem to affect things.
RV7 was replaced recently too, but I've just checked to see if it's working, and it's not! Turning it fully both ways has no affect on the screen brightness. I'd kind of convinced myself the issue was somewhere on the neck board, but it must further back in the circuit, then?
Thanks again.
gunblade
9,132CR
there are loads of components that will prevent rv7 doing anything but out of interest desolder one side of r90 and read the resistor, should be 270k
there does also seem to be an issue with the blue drive as obcd mentioned, desolder either the drive transistor or the blue gun pin to see if that loses the blue
big10p
6,092CR
I've been working through the schematic checking components around rv7. so far I've found that R93 was dead, so replaced it.
I lifted a leg of r90 and it reads OK. I've removed the blue drive transistor and the flashing seems to have gone. The transistor seems to check out OK on my little component tester gadget, so shall I just re-fit it?
Cheers!
big10p
6,092CR
Just as an experiment, I replaced the transistor with spare (used) one I had. Still get the blue flashing, so I guess the fault is somewhere else in the blue circuit. Replacing the bad r93 didn't help either as rv7 still does nothing.
big10p
6,092CR
No, it's the one with all 3 combined that's adjusted with a single adjuster knob. I did test the various resistances of it in circuit and it seems OK, but I guess I'd need to pull it to test properly?
big10p2017-08-19 13:15:57
gunblade
9,132CR
no its not the contrast pot causing this
you still have issue in the pre brightness circuit, could any number of components
blue flashing will be a fault in the blue circuit, could be a diode breaking down or a transistor-could be anywhere in the circuit as well
big10p
6,092CR
OK, thanks Grant. I was living in hope (again!) that this would be a simple fix, but it's clearly beyond my very limited skills.
I know you don't look at chassis that have been messed with, but would you be up for looking this one over? I haven't touched much since it was last working - only the bits I've mentioned in this thread. It has several trace wires on it but they all seem solid, so I think there's a bit of life left in this chassis, yet... hopefully!
If you'd rather not touch it, I'll understand, though.
