monitor lacks red
kenc
19CR
I'm in the process of reviving my GORF upright. I've replaced a bad memory card with a spare that has been sitting waiting for over a decade and it's now playable. But the colour is wrong. It's missing red. My first suspect was the rgb board, but checking the delay lines were intact and replacing the tba530 did n't fix it. So I hooked up a colour bar generator today and it looks like it's the monitor not the game. I'm hoping it's the chassis and not the tube. It's a g07-cbo. Anyone know if this a common failure mode?
There should be eight bars of colours, including black, in the next image.
3,584CR
Pretty unlikely to be the crt, most probably is the chassis. Probably a transistor on the neckboard or one in the colour mixer circuit on the chassis.
DanP
Administrator
2,232CR
For a g07 it's most likely a cold solder joint. If you wiggle the connector on the chassis do you get red occasionally?
Sbdesign
SEGA collector
1,721CR
Im no expert, they have already replied above.
But my ridge racer had no red, so I pushed on the wiring in the plug going into chassis (mainly the red wire pin) and that sorted it out.
This has happened on 3 cabs in total, so possibly the red pin not making connection?
kenc
19CR
Once again the collective wisdom of the forums comes to the rescue. I gave the connector to the monitor a wiggle and the red is back. Don't know if it's a loose connection or a bad solder join on the connection, but I now know what I'm look for. I plan to recap the chassis, so I can investigate further when I do. Thank you all.
