Monitor power connectors
maskeddev
88CR
I just went to put a hanty polo into a cab... and had a mismatch of power connectors?!
So this is what seems to be the standard, all my generic jamma cabs and more have had this connector, you know the one:
But this monitor is expecting a connector like this instead:
I'm aware of two options: I can hack the loom or I can replace the power connector on the chassis. Let's assume I'm not capable of pulling off either of those feats...
Does any sort of connector between these two exist or do we know someone who may be able to knock something up?!
Advice welcome :)
niknak
Raffles the gentleman thug
172CR
Polos don't require an ISO, so that connector is a straight 240v input, instead of the 900/9000 connector above it that required both isolated 128&240 voltages.
That Polo 3 pin mate-n-lok connector looks like it would of plugged into a electrocoin powerbrick or something similar.
EDIT
you'd need a 3 way one of these http://www.ebay.co.uk/itm/Genuine-TE-Tyco-1-to-15-Way-MATE-N-LOK-Electrical-Wiring-Multi-Connectors-/142033050277?var=&hash=item2111d45aa5:m:mwFTWkKX0W8mlUEQbZSFtcg
and a cheapo ratchet crimp tool to attach cable.
get power Somewhere in the cab - after the cab fuse - or even after the monitor fuse ideally if it has one to tap into for power, Brown (Live) and blue (Neutral) are the same as normal mains.
niknak2017-02-23 16:49:13
kiels20
125CR
Polos usualy run on 240v straight from the mains somwere in the cab (orange connector). what your cab is looking for is prob a hantarex mtc9000 or something like that. the green connnector is 128v and 240v for the degauss curcuit that comes from an isolation transformer so maybe no need to hack the loom. Find a mains input and grab it from there and use the orange plug as usual in to your polo. Hope that helps kiels202017-02-23 16:48:37
