Monitor Power Question
Paul_in_nottingham
160CR
First question has occurred to me following getting my import Space Harrier as seen in the other thread - in summary it's a US import missing the monitor.
The ISO in the cab is currently wired to 120V, but can fairly easily be wired to accept 230v, however, the output for the monitor is (according to the wiring schematic) 100V.
I was hoping to drop in a spare Hantarex mtc9000, however, these are normally powered by 128v ISO transformers. The hantarex manual states that the voltage tolerance is +10 -20%, which would make it theoretically run on 102.4 volts, close to what we will have..
So question is, will I get away with the existing ISO transformer at 100V to power a MTC9000?
tb lilley
5 Star
1,686CR
Looks doubtful. There are 2 (at least) different versions of the MTC-9000 manual, one says 128VAC +/-10% which would only go as low as 115VAC.
Be best to measure the output on the ISO, as that in itself might be +10% ......
Paul_in_nottingham
160CR
Good idea - I'll hopefully clean up the power board tonight and meter it. Can soon order a ISO off Mo if needs be - just keen to get it going ASAP!!
anj
313CR
hi on the uk one the degause is 240v on the us its 110v , the best bet may be a 110v step-down inside the cab , the 100v is ok its close enough ,
can you post some photos of the monitor power connections power supply and transformer
so i can see what you have in front of you
Paul_in_nottingham
160CR
Anj,
Not got a picture to hand, but the wiring diagram is here which details the power board.
http://tamdb.net/v2/index.php?action=downloads;sa=view;down=2028
The degauss isn't the concern as I will alter to connect the degauss switch to the 230v input, post noise filter, removing the spur off the standard 100v connection into the monitor.
Decided to stop trying to cut corners and buy a separate 128v ISO for the monitor from Mo @ Videotronics. I know it'll be the correct voltage them.
I'll rewire the connections for 230v and leave the stock ISO just supplying the 10v, 24v and 100v for the fan and marquee light.
Paul_in_nottingham2014-09-16 10:36:57
