UnclearHermit
- Credits
- 69CR
Hi. I've got a Wells Gardner 19K7689 monitor that's currently being fed by a pair of power cables coming off the isolation transformer the look perilously thin! Comparing with some AWG 22 I've got in front of me I'd say it's thinner than that. Where it then connects with the monitor (the native monitor wiring) the cable is much thicker, about the normal kind of thickness I'd expect for power cable.
Now the monitor says it's 85W max at 120V, so the amperage is less than 1A, and looking online I see that AWG 26 is rated at 1A, so maybe the existing cables are fine. But then why would the monitor internals use much thicker wiring? It's easy enough for me to rewire with thicker wire, so would appreciate any advice!
Also, what should be done about any kind of earth connection for the monitor. Obviously I've got an earth wire coming in on the mains connection into the cabinet, so should I have the monitor's metal frame (or anything else) connecting back to earth?
thanks!
thanks!
