Monitor Problem - Streets Donkey Kong
ataridude74
264CR
I picked up a Streets licensed Donkey Kong, running a Crazy Kong board.
The monitor was poor so I recapped it (all 35 of them) and the picture is a lot clearer, good colours.
But the right side of the image is distorted - squashed and curving upwards.
It can't be adjusted out by the pots, and it's not the headers as I re-flowed them.
The yoke has been played with in the past as it's not on fully tight and the convergence rings appear have been moved.
I'm thinking it could be a yoke issue - any suggestions welcome.
It's a Toei 19"CM-A20HC monitor. These are the images, sorry about the quality.
25m
75m
Title Screen (jail bars at bottom not symmetrical)
Just a picture of the marquee
5,653CR
Wow, so is the crazy kong board not original? Got any better pix?
I would think a real license would have a Nintendo PCB in it.
Would love to see better pix of the entire game.
ataridude74
264CR
It's original in so much as it's a Falcon PCB not a boot, but whether it came with the cab or has been replaced I'm not sure. It's the first Streets licensed DK I've seen so nothing to compare it with.
Any ideas about the distortion? Could it be a yoke-geometry issue?
Once it's up and running properly I'll post some proper photos, the side art matches the bezel and marquee too.
I don't rate Pauline much on the artwork, looks like she's turned middle age and let herself go (a bit like all of us!).
tb2000
3,579CR
Does look a bit like a vertical linearity fault, but presuming it's using a high impedance yoke, I'd be leaning more towards a vertical deflection transistor fault.
