Hi,
I recently bought a Wells Gardner 19K7203 to replace a worn out Kortek beasty in my Firefox. It's virtually brand new, although it may have been in storage for 5-6 years. All dreams of a lovely, pristine picture were dashed pretty quickly on power up when the monitor showed a number of faults...
- Any full-level colour filling the screen appears on the top few lines
only and is cut from the remainder. For example, white text on a solid
blue background will appear as yellow text on a black background.
Colour bars are displayed correctly and a problem only occurs when
there's a large amount of a single colour.
- Dark, horizontal bands appear across some areas of the picture. These are content dependant and don't move when the display is static.
- There is a high pitched squeel when the display is
predominantly dark. Volume depends on brightness level, starting as a ticking sound at mid brightness and developing to a full-on screaming
noise when dark. The same sound can be heard at full volume on startup
and lasts until the monitor warms up.
The Wells Gardner troubleshooting guide is not particularly useful. I
did randomly swap out C013 as one of the suggested squeel cures with no
change.
There are no obvious signs of cracked solder joints, which I've heard can be a problem with the later WGs.
Any ideas from the local monitor gurus?
I'm looking for possible diagnostics rather than suggestions to shotgun
the caps. The seller has offered a refund and I'll be taking him up on it if it looks like a repair will be expensive and/or time consuming.
Here's what the banding looks like:
..and here's a screen which should have white text on a blue background:
Firefox also has simple, primary-colour text screens with red and green which are affected in the same way.
Dave
davespicer2011-04-04 00:59:11
change.
Dave
