Monitor/PSU issue
BraveDave
74CR
Why am I getting this problem with my monitor(s)? I always thought it was just a fault with my MVS motherboard, but I’ve finally noticed I get the same fault with 3 different monitors, and two different game boards, if connected to the power supply + game harness in my BAS Jamma cab. So could it be the power supply causing the issue? Hantarex US 250.
BraveDave
74CR
Yeah, two different models of monitor/chassis as well. Is the screen voltage something that can be adjusted, or would it need some sort of repair?
3,584CR
BraveDave said:
tb2000 said:
What models of chassis are you talking about?
Hantarex MTC 9000, and a Vision KTM-F (which I believe is a rebranded Kortek KTM-F).
MTC9000 you can't adjust B+ on, not sure about the KTM-F, I think that's the same but i'm not 100% on that. Your pictures look to have too much vertical height, so you need to reduce that down for starters. That may well get rid of the retrace lines at the top. Also, you may find you need to adjust the vertical linearity once you've done that (you can't do that on the mtc9000) but it may be possibly on the other chassis).
3,584CR
Yeah I know but high b+ would also make an image too large and cause retrace lines. Wondered if somehow the PSU is overwhelming the chassis, although I don't think I've ever seen that before.
BraveDave
74CR
I’d just switched to a different game board to look at a different test screen, but didn’t adjust the vertical height for the new board, but when it’s adjusted correctly it still has this fault at the top of the screen with any game.
BraveDave
74CR
gunblade said:
screen volts not b+, screen volts is on flyback under focus
like i said earlier this is not logical
Ahh I may just be being a bit thick sorry
I always thought the “screen” pot under the focus was the brightness, but is it the screen voltage then? It does become less noticeable when I turn this down, and the raster lines disappear, but it’s still there if it’s displaying bright colours, (nothing on a dark screen), that bar at the top of the screen looks brighter/more solid than the rest.
I just plugged it in to another power supply though and there is no problem using that one.
BraveDave
74CR
Well it’s not really sorted.
If I connect any of three monitors to the power supply, harness and game boards in my Jamma cab, I get the fault. However, trying one of these monitors connected back in my Nintendo Playchoice, using the power supply etc in there, there is no fault.
