Monitor Question
jonhughes
1,156CR
Would anyone know which type of monitor would connect to a Silverline cabinet I'm going to install a monitor into please?
At first glance I saw a standard Hantarex connector - OK there. Then I couldn't find an isolation transformer. Tested the voltages on the power connector. I was getting 240 on both the supply and de-gaussing pins. Not the usual 110V & 220V.
Any idea what type of monitor went into this cabinet? I had lined up a Hantarex to go into it but looks like it would get fried with this set-up.
2,272CR
Could have been one of the Kortek chassis, one of them uses the same connections as the Hanty but can run on any voltage. Polo will run without an ISO but that's got a different power connector.
jonhughes
1,156CR
Ok thanks, it's not a type of monitor I've seen yet on my travels. I wanted to avoid wiring a different set-up in the cabinet but the rarity of this monitor type looks like I'll have no other likely option. Should be able to leave the original wiring as-is and install a transformer for the more available parts.
jonhughes
1,156CR
I have changed around the video red and blue on the video connector because I'm installing a Polo, it would have been set for older Hantarex models. I can't see any modifications on the wiring - so it came with 240v on the power.
tb2000
3,584CR
That's odd that it's got a connector like that but 240v and no 120v. As Olly says above it might've had a free voltage Kortek (or an Intervideo) chassis. Fitting a Polo should just be fairly simple.
jonhughes
1,156CR
Yes, I’m connecting the power to the Polo onto connectors of the switching PSU so won’t alter any wiring if the original monitor exists.
simonden
20 (100%)
1,042CR
Pretty sure the Free Voltage Kortek has same video pin as Polo (red pin1, Blue pin 3), so if needed to switch red and Blue, then I would suspect it was something else.
Maybe it was originally a Hanty coming of a USxxx PSU?
Either way, just put in a Polo or an ISO with a Hanty.
tb2000
3,584CR
simonden - I thought the US150/US250 psu's had the same outputs as a separate iso and jamma psu, just they are all in one? I did have a free voltage Kortek (KTM-F) chassis some time ago that, despite being free voltage, would only run on 240 (and not 120v via iso)!
jonhughes - You got a power cable for the Polo?
simonden
20 (100%)
1,042CR
Yes they do, except that the 128v monitor output is DC instead of AC. So if it had a USxxx in the cab, then it would have been sending 128v (DC) and 240v (AC) through the power cable to the monitor and degauss.
Edit:
weird, I have had a few and all i have tried on both worked on both (recently, I have just put straight to 240v, unless already has/wired for ISO)
simonden2018-06-20 13:59:46
