Monitor Question
petercasino
212CR
I've got 2 WG 19" monitors, one of which has really bad screen burn but works, and the other has a really nice tube but doesn't work.
Is it possible to swap the tubes over?One is a K7302 (nice tube) and the other one is a K7901 (bad tube).
Thanks,
Mike
petercasino
212CR
The K7302 has a faulty chassis, its tube has no screen burn.
The K7901 has a working chassis but has really bad screen burn shown below. You can barely see the game through the screen burn.
I'm not sure how to tell if the yoke is bad or I have a weak tube?
What I was wondering was whether I could just put the good tube with the working chassis to give me a nice monitor?
I guess what I should really do is send the K7302 chassis off to be repaired!
petercasino2020-07-19 13:21:33
gunblade
9,136CR
you have the monitors so you should be able to tell me whether the cables are the same
imo the only difference will be the crt earth wire, on the k7203 it will be on a single round pin connector and on the k7901 its likely to be soldered to the neck card and the power connector will be different
that only leaves the yoke, rgb and degauss connector which should be the same, crt socket should be compatible unless you have a 8 pin narrow neck on one of the tubes
tb2000
3,583CR
You want to make sure you have the same neck type as grant mentions. The K7901 could very well be the 8 pin thin neck type whereas the K7302 is more likely to be the 10 pin standard neck type. You might be able to swap over the neckboards though if that's the case, I can't remember off the top of my head if they're interchangeable or not.
Edit: And that is some awesome burn! I had a G07 with burn as heavy as that a few years ago out of a Crystal Castles cab, looked quite weird as you could almost see all the level layouts overlaid on each other!
tb20002020-07-20 17:25:57
petercasino
212CR
Ok thanks I’ll check this weekend and might upload some pictures to double check.
Yeah the burn gives a weird effect, never seen it that bad before, you can literally see none of the game on the top third!
