Monitor screen shows compressed picture
Franks_Arcade
5CR
Hello,
I have on my crazy kong arcade machine the following issue on the monitor.
A compressed screen appears. The picture is on one side o.k. on the other side compressed.
Details see pictures.
Any suggestions ? I tried all adjustment pots, but can´t get a good result. The red picture is only
to show the issue. I adusted the red pot to max.
Thank you in advanced
Frank
Franks_Arcade
5CR
Unfortunately, the issue appeared after installing the cap kit. I checked every cap concerning the values and plus/minus, everything seemed all right.
SUPERSPRINT
1,035CR
may be a vertical ic issue. Can you check it with a meter? If you get really stuck there are some monitor repair specialists here. Gunblade and tb2000 if I'm correct.
