Monitor Shadowing Issue (SOLVED)
dj_yt
787CR
Hello.
Picked up a cab recently. Monitor looks and works fine with my MVS.
However, the PCBs I've tried have a bad 'shadowing' problem. The top of the picture is wavy, and black and white colours seem to shadow.
Chassis is a WG K7000.
Is it a convergence issue and why would the MVS look fine and the other PCBs look so horrendous??
dj_yt2015-10-08 22:02:05
tin
673CR
That looks more like a problem with the signal cables than the monitor itself to me. Same cables MVS vs other boards?
dj_yt
787CR
Yep, just the standard cabinet JAMMA harness going to the PCB's JAMMA adapter.
The PCBs work fine with my SuperGun setup of course.
dj_yt
787CR
Hmm... so one common thing I've noticed is that on both the JAMMA adapter for my Bubble Bobble and the System 16 adapter I'm using, video ground isn't wired up. Could this be the issue? It looks like something along these lines...
obcd
3,830CR
If you don't have a proper ground wire from your monitor to your game board, this could indeed be related to the problem.
dj_yt
787CR
Yep. As suspected. Resoldered this bubble Bobble adapter and working fine!
Offset top rows were simply a horizontal hold issue.
What threw me was both adapters being wired wrongly!!
