Monitor Shorting Voltage Regulator
ataridude74
265CR
The monitor in my latest cab worked very briefly, had neck glow.
Since then it has not worked, and has the following symptoms
Voltage Regulator shorts in voltage supply circuit.... then
A resistor overheats and smokes.
I've tested every component out of circuit, and they work fine... but
in circuit I get some odd readings - diodes reading both directions, transistors reading variously across E-B, E-C, C-B and C-E as well as the proper way.
What is going on? Have I got a short somewhere?
So frustrating, I was even thinking of recreating the voltage supply circuit on a breadboard and tapping in further down the line.
It's a B&W Motorola M5000 by the way, loads of them in Space Invaders.
RGP
Meeter & Greeter
2,039CR
It sounds like a short on the board to me.
Your E-B, E-C, C-B, C-E readings on transistors are common in some places if they are find out of circuit you're good.
Test on continuity between an input point and an output point and see if you get a beep continuously not just a short beep.
I'm looking at this schematic:
http://arcarc.xmission.com/PDF_Monitors/Motorola%20M5000-155%20and%20M7000-155%20Schematics.pdf
Are you talking about Q17 and R84?
I would clip the negative lead to a ground point first.
Then lift one leg of D16-D19 and then test between ground and points along the circuit.
This kind of overheat is caused by a direct short to ground or short across a diode junction in something.
Given that resistors "usually" burn out (go open) I would think its safe to say that the resistors just before ground are probably ok.
If you have lifted every component out and they are fine out of circuit then you probably have a short somewhere.
That monitor isn't filled with isolation points like some others. If you can isolate the +73v output stage from the rest of the board (is it a wire link on those?) you can at least figure out if the problem is before or after the output to the rest of the deflection and drive.
I've built parts of circuits on breadboard to prove them and its increased my knowledge massively by playing with an isolated circuit.
Which resistor is overheating and smoking? Main power bleed resistor R84?
big10p
Coins detected in pocket!
6,093CR
I'm not familiar with this monitor, but have you checked the transistor isn't shorting on the heatsink? I'd be tempted to replace it just to rule it out, TBH. But that's just me.
RGP
Meeter & Greeter
2,039CR
Haha! That's an unbelievably good point!
ataridude74
265CR
Thanks dudes. It's not the transistor shorting to the heatsink. It will short it out immediately if I turn it on, but the current one is good.
The resistor which is burning out is R87, looks a bit toasty already but still reading 820ohms.
It sounds like a short, I pulled a leg out of D16-19 as suggested, the rail which has -ve of C18 an C19 on it is shorted to ground when continuity tested with the meter, also has the R87 negative lead which is burning up.
Isolating +73 wouldn't be easy, it would involve pulling a whole load of resistor legs, sounds like a recipe for more smoke.
Problem is with the breadboard idea, where to stop before I end up building a whole new board? It's a bit scorched around R87.
Your help is much appreciated. This monitor is driving me mad!
big10p
6,093CR
Just remembered I had a monitor that was driving me nuts, as all components on the chassis tested OK. I can't remember exactly what the symptoms were (think it may have been overheating power resistor and weird B+ voltage), but it turned out the chassis was fine, but the deflection yoke had shorted on the tube. Long shot I guess, but thought I'd mention it, just in case.
big10p2016-07-14 23:18:12
