Monitor showing green only?
_Matt_
965CR
Hi guys. I've got a problem with this monitor. Here's a couple of pics to give you an idea of what's going on.
12_19.52.39.jpg" />
If you turn up the red fully you get literally a few lines of red mixed in with the green and same if you turn up the blue.
It's a Hantarex monitor, here's a couple of pics showing the chassis and the model number. I know very little about monitors so any help woukd be greatly appreciated. I can upload more pics if needed.
Bonus points if you can work out what the game is. (It's nothing exciting)
Thanks guys.
big10p
Coins detected in pocket!
6,092CR
Well, it's an MTC 9000 - older model I think, as it has the individual RGB preset contrast switches (circled in red).
What exactly did you adjust when you say you turned the red and green up?
Also, looks like the clip that holds IC1 to the heatsink (circled in yellow) has broken or come adrift. This might be shorting pins on IC1? Probably not the issue here though.
big10p2016-03-12 20:38:17
_Matt_
965CR
Thanks for the replies so far fellas. My mate was doing that part and he said it was the three things on the circuit board on end of the tube. They seemed to do colour RGB.
_Matt_
965CR
Great news! I had a fiddle with the contrast switches as gunblade suggested and it's pretty much sorted. Just need to have a bit more of a play around to get the picture perfect.
My test pcb Squash
Good opportunity to test a game I received off Milky the other day.
Thanks a lot gunblade and thanks to everyone that helped. Didn't realise it was such an easy fix.
