Monitor swap
J69
281CR
Sorry to be a noob but my monitor expertise extends to adjusting the pots to get a better picture.
I want to swap the monitors in my Outrun and Afterburner (Afterburner is the rougher cab but has the nicer monitor).
If they have the same chassis can I just swap the tubes?
If not do I have to transfer tube and chassis?
eggplantUK
19CR
So long as they're physically the same size / will fit the other monitor mount, you can just swap the tubes if the chassis are the same. However, it seems silly to do so if the chassis is mounted to the tube.
Whether a different chassis will fit on a particular tube varies from case to case.
