Monitor sync on certain PCBs
86CR
Picked up a new PCB and having a nightmare getting the monitor to adjust for it. Can adjust for all my other boards but this one is always out no matter what I do.
Anyone else have this on a PCB from time to time?
PCB is World Rally
Monitor is Kortek ktx-26
Board displays fine in my Polo
Noticed in the manual it says about video ground required, checked my harness and it looks fine, although my video ground has a resistor from that pin to speaker - too.
86CR
Goodwinsplace2021-03-14 12:37:36
86CR
gunblade said:
is it vertical roll you are getting?
No I can fix the vertical, this image is from dip 2 switch one set to on for the board test screen.
Top half is spot on but can't get whole picture.
With the resistor back in place.
Goodwinsplace2021-03-14 17:05:15
gunblade
9,132CR
did you try any of the sync switches on the chassis?
have you tried to link vertical and horizontal sync together on the chassis rgb input connector?
86CR
Switches do make a difference. Now it looks a clear image but horizontal scrolling.
Can't lock it in using h-hold. And tried adjusting on h-pos but that is right in the middle of the chassis and a pain to get to.
86CR
gunblade said:
try linking the v and h sync now- just put a temporary short on
H sync (yellow) isn't connected to anything. Have a few connectors further down the wiring too.
Shall I use the v sync white connector down further to connect this in?
Goodwinsplace2021-03-14 17:59:34
86CR
Edit: test screen is great but actual game is still not syncing properly. Bloody game, never had issues like this before.
Awesome. Connected it in and can sync it now.
Still more work to do on this monitor but will follow up on another thread as need to take some readings on it first of B+ and other things.
Thanks for the help, really appreciate it.
Goodwinsplace2021-03-14 19:00:27
